0 Members and 345 Guests are viewing this topic.
Hoppy
Quote from: magpwr on June 24, 2015, 09:13:17 AM
To Hoppy,
I only got 1 request for Mr Smart Ruslan.That is if he can perform same demonstration on hard concrete ground with just 1 cable or wire to Earth.Bulbs and device on concrete ground like Akula style.
We know that Ruslan have taken the trouble previously to demonstrate and even explain a fake running device.Please correct me if i am wrong. 8)
I do hate to say this but Ruslan have picked a most grassy spot to perform this experiment to likely conceal a fake.
A hard concrete ground is a fair request from me without even bothering to ask how his device works.Not too much to ask i hope.
By the way stop waiting for answers or solution from anyone eg:Ruslan.Stop Dreaming about it.
Seems like some of you would fall under this category buy a electronics DIY kit with instructions to assemble/solder a circuit yourself -A no brainer experiment.
Agreed. Its a no-brainer that hard concrete ground is certainly preferable to grass for a demo!
The shots I posted need no explanation and show how poor Ruslan's demo was to conceal traces of fakery. It was so bad that I'm beginning to think that he wanted us all to believe it was faked!
NickZ
  Magpwr:
  You know it all, we are the fools...   Thanks, now we know.
  How about showing us just what you really know, by showing us your self runner.
  Or, did you give up already, because you think it's all faked?  Or, do you like replicating fakes?
Hoppy
Quote from: forest on June 24, 2015, 09:38:19 AM
Hoppy,  I thought I explained in plain English, no ? Before transformer you have 230V AC 1A after you have 230V AC 10A. Timing is made by rotary spark gap in sealed box or just a DC relay working with diode bridge or single diode and adjusted to break circuit just before the current peak . If you know Russian you will recognize this is exactly what Ruslan is talking about. You need thick ground wire to suck electrons from ground...
Thanks for your explanation Forest.
It's now fairly clear to me that all the self-running demos we have witnessed on the fora, utilise hidden external / internal power supplies. The 'effect' relates to a transformation of energy which is either genuine or perceived as being an overall input to output gain. I think we can now drop the search for the hidden 'X' wires by assuming they will always be present. The focus needs to be on constructing the 'so simple you'll laugh' type setups along the lines that you showed in your schematic and determining by proper measurement whether there is or is not a real system throughput energy gain.
NickZ
  Well, so now all we need is for someone to show how you get 10 times more amp output, by just using a simple spark gap.
  That's it, and that's all.  Or is it?
Hoppy
Quote from: NickZ on June 24, 2015, 10:15:47 AM
Not just a focus on amps Nick. You should have learnt by now that volts come into the power equation as well. You wanted simple, so you can run now by following Forest's lead!
