0 Members and 86 Guests are viewing this topic.
verpies
Quote from: yfree on November 29, 2012, 09:00:27 PM
Low duty cycle is not the same as low pulse repetition frequency. :)
It is if you consider the condition, I imposed: "for the same pulse widths" :)
The broadest spectrum of component frequencies is not what is necessarily needed, but rather a dense spectrum of frequencies in a band of frequencies.
Yes, a dense spectrum is the goal - not a broad spectrum.
A careless choice of words on my part :(
P.S.
On this diagram, the Gain Medium should extend further away from the axis of the Spool.  I drew it this was only to avoid obscuring the white iso-B contour.
Here is a interesting task: Design a practical confinement system in which the outside magnetic field is parallel on both sides of the Gain Medium yet perpendicular inside it.
Сергей В.
Привет Itsunadze and all
Before experiment look carefully this OU video by Tigar2007. It's parametric excitation LF contour with HF pulses. As you can see or calculate he catch the goal. On oscillograph screen you clearly see Over-Unity !!. He got it. He made excitation only on positive half-cycle of sin(x) contour. To doing this you need precise synchronization your VCO Nano-Pulser on Master Oscillator which give 110Volts (Frequency unknown). In video Dally said his ГНСИ or Nano-Pulser working on 12KHz. Still wainting answers from him and his oscillograms. I don't know what happened with him!
OU 200Vsin pump on 400Vsin
http://www.youtube.com/watch?v=Um7J_5FwVq0
Try excitation on positive and negative half-cycle of Sin wave !!
verpies
Quote from: Сергей В. on December 02, 2012, 04:11:10 AM
That's an encouraging video but on the oscilloscope I cannot see the nanopulses superimposed on the peaks of the low frequency signal (310kHz 200VP-P) as shown on the hand drawn diagram, appearing at the beginning of that video.
I can only see the low frequency signal increasing to 400VP-P after the application of the second signal (allegedly high frequency).
I like the way the effect spontaneously drifts away and disappears.
I am sure that Itsu is hitting the peak of the sinewave with his nanopulses, from time to time, but his indicator (light bulb) is too slow to react to rare anomalous events.
P.S.
What does Tiger2009ify say about the magnetostriction in that video?
T-1000
Quote from: verpies on December 02, 2012, 05:43:31 AM
P.S.
The nanopulses from secondary synchronized generator are in wrong direction there. Also ampmeter shows more drawn of energy when nanopulser are connected. Any attempt to take energy out of that system would ruin resonant conditions...
Also tiger was attempting to get away from magnetostriction. This is what ruined Itsus's small toroid when magnetostriction gone into mechanical resonance.
verpies
Quote from: T-1000 on December 02, 2012, 07:46:29 AM
The polarity of the nanopulses is in the wrong direction or the direction of oscillator synchronization is in the wrong direction (LF->HF) ?
You think so?
BTW: Ammeters do not measure energy.
Magnetostriction is not always bad.
For example: Graham Gunderson has a patent of a device that relies on magnetostriction and acoustic standing waves in ferromagnetic cores to generate energy.
In your opinion, what is responsible for the increase of the amplitude from 200VP-P to 400VP-P ?
