0 Members and 295 Guests are viewing this topic.
verpies
Quote from: Dog-One on June 29, 2015, 07:02:34 PM
The only core used in this device is the toroid yoke and you feel quite certain this is being saturated.
Yes
You are pretty confident NMR comes into play here?
I have seen no measurements that indicate NMR.
NMR by itself is nothing unusual but transmutation caused by it is.
So what frequencies might be responsible?  Both the kHz and MHz?
Yes, because Larmor precession frequency depends linearly on magnetic flux density.
So for example:
at 1 Gauss iron nuclei will resonate at 138Hz,
at 0.5 Tesla they will resonate at 690kHz,
at 1 Tesla they will resonate 1.38MHz,
and so on...
verpies
Quote from: NickZ on June 29, 2015, 12:04:15 PM
Not laughing off anything. But, NMR has not been proved to be the cause of the Kapanadze/Akula/Ruslan device effects.
Yes, it has not been proven one way or the other, but my point is that the conditions for creating NMR are so ubiquitous that it very likely to be happening to some degree anywhere you have orthogonal magnetic fields.
My conclusion was that you should not be having an issue with NMR occurring in these devices, but with EM caused transmutation as the energy source.
I will have no problem with your objections if you substitute the word "transmutation" for "NMR" in them.
As I know that you only believe in what you can see, feel, or measure with existing instruments, so, I won't get into FIELD EFFECTS with you.
I consider anything that makes sense and it does not have to be mainstream.
For example this.
starcruiser
AS far as determining the wire length goes you can find calculators on the internet that will tell you wire length versus frequency, i.e. wavelength. This is what I have done and doing to determine the correct wire lengths. So far everything is following standard theory.
I also used the calculations (formulas) to determine circumference and the required number of turns per layer (N) and the subsequent layer (N-1) layers 1 & 2, then 50% of those winds for the 3rd layer and less one etc to figure out the actual coil length required to make it all fit on my form. This will take a bit of math and some critical thinking to figure out how to wind the grenande coil properly the first time. Or you can do it by trial and error, i.e. wind and unwind until you get it right.
As mentioned by me and others (T-1000) you can construct the grenade coil first and then tune the Tesla secondary (fine tune it), TBH I wound the Tesla Secondary first using the wavelength info to target the 1.8Mhz frequency, then wound the 168(ish) turn grenade coil at 1/2 wavelength, the next coil will be at 1/4 wavelength, these will be tuned using the capacitors in conjunction wit the yoke coils since these will impact the operating frequency of these tank circuits.
And that is what these are, tank circuits and filters which will pass or block certain frequencies (high pass/low pass etc), I think if these are tuned properly you should be able to get your setups working. The capacitors and coil configurations look to be high pass filters, capacitance in series with the coils, where low pass would have the capacitors in parallel to the coils. Some of the other items are RC time constants (Capacitor charging time) to control the PLL and the logic circuits (pulse delay).
I would tell you to start out by measuring the inductance of your coils and look at the capacitance values and calculate the operating curves of these filters, this will tell you the cut off and such. If you do not know the formulas look them up on a wiki or something. Lets stop running around in the dark here guys, a lot of this can be figured out with a calculator and some math equations. This will get you in the ball park and then tweaking can commence.
This is what these guys are doing (Tariel and Ruslan), using some common sense and math. This is why I said earlier that a basic understanding of electronics is a requirement here. Don't you think its a coincidence that Ruslan and Tariel both are radio guys? they understand these things, wavelengths and filters, etc.
Sorry if this is a rant, but I wanted to get you guys some useful info, do a bit of research and some tests and measure, this will help you tweak your setups.
Regards,
Carl
NickZ
  I think that I've already explained my views, on how these types of systems may work. By the extraction (havesting, tapping, etz.), of energy from the surrounding ambient, and not by NMR nor transmutation.  But by the same reason that all generators work. Similar to when passing magnets by coils.  Only these are solid state versions, which are using the additional or extra output to feed back to the input.
  This is not a new theory invented by me,  it's the same theories and ideologies fully explained by Tesla, and others. Although Tesla may have never shown a free energy device to the public. And even put his Pierce Arrow car away, for good, but it was self runner, all the same.
  So, where does the extra energy come from?  The same answer, the Aether.  Believe it, or not,  I aim to prove it. With "conviction", like Hoppy says.  This involves the belief in an Aether, the vortex theory, and the ability of tapping of the existing surrounding energy fields.
And, That, may be where we have to agree to disagree.
   So, as far as I'm concerned, or have seen, felt, or measured,  there is no NMR, nor evidence of transmutation, in THESE Akula/Ruslan devices.  Nor Alfa, Beta, nuclear decay, etz... When I turn off my device, it stays off, does not glow at night, nor emit Beta, afterwards.
These Akula/Ruslan devices are energy conversion systems.
  If these devices that were running on such forms of energy systems, such as NMR, I would not be working on them.
  However, I respect any ones work (even ATOM1), even if we may disagree on principles, or causes, especially if there is a working, proven, free energy device, that works as stated.    Is there one Atom1?  Can you show it running, no?  Just teasing us? No prize...
  BTW: Verpies, what are your thoughts on Thorium???  You can PM me if you like.
        NickZ
ATOM1
DONT GET WRONG SON !
New theory or old theory is just theory ! Ambient ,radiant, ground electrons, earth resonance, dynamic harmonic response with  some forms of quantum entanglement,  electron propagation, photon propagation, splitting neutrons to produce sea of electrons . negative electron field dumps .. Thermo dynamic displacement of hydrogen ! Even just atomic pressure release from covalent bonds in water, gravity, magnetic inertia, electron excitation of streaming x y electron mass. interstellar radiation ... electron release of electrons in silver atoms . Harmonic unity of the covalent bonds, Electro chemical reactivity as a thermodynamic process of unity releasing atomic pressure. proton depletion ! AND THE LIST GOES ON ! NOW WHERE IS THIS OVER UNITY ????
The only man ever to achieve that was Christ ! Now you go and feed 5000 hungry people with 5 fish and 5 bread roles ! ok
good luck
ATOM1
