0 Members and 285 Guests are viewing this topic.
Dog-One
Quote from: NickZ on July 02, 2015, 10:50:30 AM
As in this case, the earth ground line (thick black copper cable) is also a tune 40 meter long antenna, coiled at the end for fine tuning of the
best frequency, just before going to the ground rod.
Ruslan clearly states the ground wire length extends the length of the Tesla secondary.  So if the Telsa secondary is tuned to 1/4 or 1/2 wavelength of the grenade coil, I would have to guess the five or so windings that reverse direction at the end of the Tesla secondary is to back-out the offset of the ground wire--though five turns on a 50mm tube hardly seems enough.
Again, this is why I think we need to establish the relationship between wire length and Tesla wavelength, without that this all becomes a crap shoot.
NickZ
  Any change in the device parameters will effect the running frequencies, and you will have to start from scratch, again, and re-tune everything.
That is much harder to do, than to just follow the existing information, on coil dimensions, and ground connection which has is already been provided.
   Dog-One:
   "Ruslan clearly states the ground wire length extends the length of the Tesla secondary.
    I think that what he means is that the grounding of the Kacher at the start of the secondary coil, adds to the output power of the antenna/capacitor coil. Not to the "lenght" of the kacher's secondary coil.
   In my case that does nothing to add to the output, and I have to connect my earth ground to the Kacher's transistor emitter (negative rail). Which does increase the output at the antenna coil.
Dog-One
Quote from: NickZ on July 02, 2015, 11:11:45 AM
I can tell you as a matter of fact if you make the inductor one half wire length of the grenade using the same wire, you will need three layers (not two).  So clearly there is an inconsistency in the "existing information".  This is why we need to get at the root and figure out exactly what is meant be "length".
In this video at about 13 minutes, Ruslan pulls up an application to make some calculations.  Do we know if this program is tailored for Tesla type data?  Or is it strictly for standard Hertzian work?
https://www.youtube.com/watch?v=f9djNfcKu3Q
And again, you're guessing.  And doing that about a very obscure technology very few fully understand will take many lifetimes to be successful at.  Trimming a centimeter at a time on one of these coils is akin to the old CB'ers trimming their antennas, only it will take a lot longer since you don't even have a base reference to start with.
Look at material Acca posted regarding Tesla Waves.  Do you understand how to calculate those lengths in red?  I don't.
Hoppy
Quote from: Dog-One on July 02, 2015, 12:38:26 PM
Yes, constant guessing from both the faking and believing camps. The blind leading the blind. No real evidence of authenticity or fakery. Fuzzy, badly produced videos claiming self-running. A sad state of affairs!  :(
AlienGrey
Calculating wave length first find speed of a radio wave, it's 300,000,000 meters a second as far as i know, i think Ruslan said the grenage coil was 37.5 meters so devide that into 300 x10-6 gives you 8 Mhz easy so it's velocity Lambda = V/ f  if in doubt look it up. so if your 50 turn coil is 2/37.5 meters it's 16 mhz./ serch me how it works but it is in resonance if it's spot on ! as the tesla coil it 2mhz.
