0 Members and 232 Guests are viewing this topic.
John.K1
Hi Tomtech
Just something different.  I just didn't like that "antenna" :)  Want to do  "proper" Tesla coil (3coils in total) .  The design I made is still not perfect. The secondary coil should be made of stripe (tape). I have non. It will be next upgrade ;)
AlienGrey
John k1, the  55.55 mtrs works out to  = 5.400540054005401 mhz is that right ??
2 mhz would be 150 mtrs.
I my self was thinking of using a copper pipe of about 2" and cutting a slit down the length, as the primary and just tuning the device for optimum resonance at 2 or 1.5 mhz  far less chance of it becoming a theremin ;) one could then possibly drive it with a 1.5mhz clock derived from a Xtal at 6 or 3 mhz by division and then dividing it down by 100 to drive the current driver, but not sure if a phase shift would be required for fine tuning, just a thought, with what's being said.
Tomtech 29
Try the Edgeware road loads of electronics shops their , go on the Tube ! or try RS if you can find one look on the net for them RS components.  good luck !
John.K1
Alien,
Tesla is 1/4 wave coil .  One primary and two 1/4 coils. Secondary should have high capacitance and the Tesla coil low capacitance . Not sure if there must be any differential interface (not to form one  1/2 wave coil) or the different properties of coils and the distance between them will still treat it as a two 1/4s.   Tomorrow experiments will tell.  Where is TK when you need him :)
Dog-One
Comment from Ruslan:
Quote from: Ruslan Kulabuhov
You can do without a PLL. But we must clearly align frequency. 1:100
The coils are wound in the same direction. This acceleration of the oscillatory circuit.
I assume he means with a static load.
NickZ
    T-1000:
    Why I'm not on Skype?  Because I don't use Skype, nor need to talk to anyone other than Ruslan or Oleg. Nor do I speak Russian, like you do.
    Any way, that's ok,
    Thanks.
    John.k1:  This Ruslan video below is showing what I think may be the best Kacher circuit to try to replicated.
   https://www.youtube.com/watch?v=UPWf4Rugy4g
   quote: "Btw- I have made my push-pull from ofshelf 555 tunable oscilator and runs the 4x divider (on gates is going 2nd and 4th signal".
   Can you show your push-pull device working and lighting some bigger wattage bulbs yet?
