0 Members and 301 Guests are viewing this topic.
Tomtech29
as I listened to the end it is the 300+200+500+60+200 = the total value of 1260Watt.hmm :-\
less than 6 Amps at 24 Volts DC.
-you guys admit that there is no option to run the system with the system Kacher!.
(there is a system to control the pulse Tesla coil) nothing new but the other options do not have the right to exist.
It's just that the movie is all tm buried and can not understand what is hiding there?
John.K1
Hi Guys,
Today I connected my new Tesla coils with Kacher and  on the scope I could read the frequency 720KHz. Tha's aproximatelly 1/2 of my target frequency (1.36MHz - 1.5MHz). This means , my two 1/4 coils together work as 1/2 wave coil.  So, I separated them and checked only  the secondary coil  the result is  1.5MHz as it should. Of-course with only secondary coil  less wire -less output voltage. The question is how to connect both coils (secondary and Tesla)  together ,so they behave like 1/4 wave and to reach of increase of voltage. After many tries I just putted between the secondary coil and the Tesla coil ferite rod with two coils. The secondary and the Tesla are connected just by on wire to each coil (they're not electrically connected) and now the output frequency is around 1.2MHz and the CLF lights bright in distance. It takes around 0.8A @ 9V
I just need to tweak the number of turns on the ferite rod to get my 1.36MHz. So far I feel I am on the good path.
NickZ
  Tomtech:
   I think that the diode bridge like Ruslan is showing, is more efficient, and has much better cooling, although, it may even need a fan on it, also.  But, that full bridge rectifier was still is not good enough for the whole 4000w load of worth of bulbs, without overheating.
   Using the right bridge rectifier diodes (10amp diodes?), the 75v, 200w mosfets, and those 2 WIMA (0.47uf) caps, are part of the trick to obtain the higher output levels and more optimum running frequencies. Also using the right bulbs is most important, as they are part of the circuit, and using smaller bulbs just won't pull the feed-back power back through the system, and therefore it won't self run. But, not one person has done so, using all those same components, and so face disappointing results, using other parts, with different specs, than the recommended component. Which are normally not to be found in ones electronics junk pile.
  John.k1:  Your frequency will also change if you use 12v, or 24v, and 2 to 4 amps input, as Ruslan does.
Dog-One
Quote from: John.K1 on July 11, 2015, 06:39:21 PM
Hi Guys,
Very encouraging John.  You might try reducing the number of turns on your primary.  In my case that jumped me from 3MHz to 4MHz which is too high, but now I can see how to increase frequency pretty easily.  Looks like more turns on the secondary is needed to get things in the 1.9MHz range my grenade coil runs at.
If you would, please scribble out the details (picture) of what you just mentioned.  I'm at a perfect point to experiment with it.  If what I'm hearing you say is correct, you have rediscovered a way to increase voltage without decreasing frequency, just by separating the secondary and Tesla coils with the ferrite rod trick Akula first showed us.  Are both the secondary and Tesla coils wound in the same direction?  And is that the same as the primary too?
John.K1
Hi Dog,  My primary is just one turn :) So direction of the primary is very lightly defined.
So far I it doesn't looks like the direction of turns is important, but I can't say this on 100 %  I only know I used the rod where the coils are same direction and I also used the toroids and chokes with opposite direction and all this works fine. In fact bifillar- air core -seems to be working too.  Just I can see the number of turns and the size of wire makes the differences.
Too late here , will continue tomorrow. Maybe I will make some video ;)
