0 Members and 257 Guests are viewing this topic.
NickZ
   Zeitmachine: Are you so afraid of the men in black? So much so, that you and others need to constantly ridicule even honest people trying to build something that works, also. Is that how you get your kicks.
Since you are not building anything related to this thread, it must be how you get off. Who are you concerned about? Saving our time and money?  Sure... more like wasting our time with more useless posts, I would say.
Hoppy
Quote from: Dog-One on July 15, 2015, 02:59:31 PM
I'm not going to horse around with phase locking.  Not at this stage.  The goal is to run a fixed frequency setup with a fixed load.
Good initial move. As T1000 commented a few posts back, try sweeping ultrasonic frequencies to establish best frequency for a given lamp load. I suspect that this very important. Clearly, a permanently connected power supply must be used for all these devices, so its a case of getting the best light output v input energy. I've done this experiment with halogen bulbs with interesting results. Its even possible to cleanly detach the halogen filament supports with the right frequency. All lamp filaments have some inductance, so look for resonance.
Tomtech29
"AlienGrey
Jr."(Now the diagram you have posted is interesting, Have you tried connecting a scope to it and looking at the wave form ?)
This arrangement is similar but I suppose that's not what "Oleg" presented
waveforms showed: Bat1Robin2 on page 606 -I asked him once about the show all runs on the gates of transistors but did not answer
He began to personally to perform only part of the integrated circuit 74HC00 and 74nc14 I could not set it up
I have not seen the entire system It operates as shown in :Oleg"  I have no information what kind of chips it uses
as someone to share the full specification should be readable for all to piece together and play in tune I would like the PCB see how it works and understand what I can change it.
Here everyone working on the same device driver for PCB nobody showed  the secrets of how to do all they put together and lakes is the effect of his work.
Ruslan how does the secrets he does not want to share control systems What happened that not telling about the possibilities of making further progress ?
What about the fact that someone showed ready kit as no one explains how it works and what so I imagined otherwise it's pointless  to whom it is intended?
Dog-One
So here are some shots of what gating looks like:  1.78MHz inside a 17.8KHz sync pulse.
The top (yellow) trace is the gating signal to the MOSFET driver.  I set the pulse width to grab approximately 11 full cycles.  It will be nice when T-1000 gets back and mentions just how wide this should be.  My thinking is only as wide as necessary; anything that doesn't add power to the system is wasted.  Plus the shorter, the cooler the gate driver and MOSFET run.
The bottom (blue) trace is just a looped probe near the illuminated CFL and antenna.  I can't explain the crazy signal there--seems to me it contains a whole boatload of harmonics.
Also, don't pay any attention to the frequency counter measurement in the lower left corner--it gets a little confused with these type of mixed signals, just like people do.
AlienGrey
Tomtech I don't have a PCB for it, i just used a bread board layout and a 3 mhz clock input into a 4013 to give 1.5 mhz and a 4518 to divide by 100 to give 15 khz then fed that into the 4093 to get the required display ----!!---- you can shift around and alter it's width and just feed the output into the IR inverter driver chip, no problem. but cmos is a 12 volt  to 15 volt device not 5volt system.
The idea is not new at all you will find other articles on it SERPS  look up Jim Murray and Paul Babcock COP system.
Note the 4093 is a Schmitt trigger device and so is the 74hc132, and  the 74 hc00 is not and wont work in this circuit correctly and 74 series is a 5v system.
If you made a system like they are talking about you would need to monitor the output drive for zero cross with a 311 op amp and lock a 4046 PLL 1.5mhz crossing phase to the current driver, for resonance I would think. I haven't got that far yet ! as I don't have the wire to wind the coils as such and i have run out of bread board !
