0 Members and 57 Guests are viewing this topic.
Tomtech29
T-1000 is what you showed it through the eyes of Ruslan said that he used a mechanical way it was a key relay :D
T-1000
Quote from: Tomtech29 on July 16, 2015, 12:02:00 PM
..Now the question about the chip  Ic1 14hc00
at which the maximum frequency will be operated?
-and no push-pull (and no longer needed (pack)*(a system for control of stabilizer) and is not synchronized with the TT circuit controller? I have to try it out!.
https://physics.ucsd.edu/neurophysics/courses/physics_120/74HC00_QUAD_NAND.pdf
Push pull is for a starters there with no PLL but it is not hard to add that to control TL494 chip...
Tomtech29
This surprised me quietly 500Watt with the same push-pull and here you have to think about
https://www.youtube.com/watch?v=U_6dSh3hCO0
what is high (K.P.D)?
which makes giving him the power output?
Hoppy
Quote from: NickZ on July 16, 2015, 11:40:07 AM
    Hoppy:
   On the other hand, is there another solid state, (non-moving), device that is giving better results, and that is being replicated with success? No that I've seen, in any of the different forum topics, nor anywhere else.
   I do want to mention that, when I short circuit the 0.47uf caps on the 3 turns coil, with screwdriver, I observe a much stronger output at the 168 turns output coil, and bulbs. And, a stronger spark at these caps when things are in resonance. As well a much stronger feed-back circuits voltage and current levels.
Could this be the coil shorting effect that is being discuss elsewhere???
Nick,
I've yet to see a good demonstration of any device that could provide a reliable benchmark for comparison with other devices.
Might suggest timing of short circuit interruptions are are an important clue to the correct functioning of this type of device.
NickZ
  Tomtech:
   In that video, it is not the same snubber circuit on the mosfets. So, not the same push-pull circuit, as the later videos.
   Are you saying that there is a self running device that does not have or use the push-pull system? Or what?
