0 Members and 534 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on July 17, 2015, 10:08:18 AM
Are you lighting 5 100w bulbs using only 27 watts???
What should be the problem with that? Darkness favors secret dealings. 8)
If we connect 5 100W bulbs to 220V in series then each bulb runs on a fifth of its rated voltage.
A 100W bulb at 220V draws 0.45A and has a resistance of 484 Ohms. Running that bulb at 44V (220 divided by 5) equals 0.09A and 4W for each bulb. 4W × 5 = 20W.
That means we can simply connect 5 100W bulbs in series to 220V without the need of fancy coils, electronics and push-pull drivers. We will get a bit of illumination anyway.
Correct me if I'm wrong.  :)
Hoppy
Quote from: DA1 on July 17, 2015, 12:05:53 PM
Nickz  In addition, the system will consume 150 w max to power on its own.
The Pebble will flow out of use Eng.
Hmm, still no clear yes or no answer.
Tomtech29
"Zeitmaschine"  You need to check because I see a parallel circuit bulbs ::) This total power load 500Watt
you're right in series but the light is not scattered see how the cables are connected friend: ;)
Tomtech29
 ;D very fast diode in a place where we have lines plus -This means half
one part of a winding work and the other is at a constant voltage
by the way they have a nice spark white  which gives him a high voltage to light bulbs and the current LC.  :D
but what where is the reward?
AlienGrey
He DA1 is just saying he can do PCB's, perhaps he just want's art work sending and he makes what you want, end of story ? thats what i'm getting other than that he is not saying. not yet any way !
