0 Members and 78 Guests are viewing this topic.
itsu
Thanks guys,  youre welcome.
I will be doing some tests now and then and perhaps some new info will pop up, so we don't close this book yet.
Regards itsu
Сергей В.
Itsunadze привет
No news from Dally like he was disappeared in earth, but somebody has wrote in Dally blog and informed all that he have success. According to his info i made a new schematic. He was lightened bulb on full brightenes. Conect coax like on schematic and try. His coil on pvp pipe have diamter 5 cm, lenght 30 cm. 1st 1000 turns #0.3mm, 2nd 100 turns #1mm, 3rd coax on full lenght 30cm. He conected light bulb on 2nd winding 1mm. Try first on your 4th winding when on 2nd. Effect is much bigger when he has putted ferrite rods inside coil. He was melted some conductors from excessive power. So coax imput was shorted and conected on trans, coax output was shorted and conected on ground braid. I don't know did anode of DSRD was on the mass or not. Try first without and than with mass.
Reg. Сергей В.
mihai.isteniuc
Hello 2 all,
I have to agree somehow with Сергей В. In my tests I have discovered that the L3 has a greater influence over the entire coil if the nanopulser it's connected over the shield of coaxial cable. Also my 400v capacitor connected in parallel with L2 has been melted during this tests. At the moment I'm still chasing for a nanopulse narrow then 9-10ns and with a decent amplitude, and also capable to go beyond 8 Khz PRF (@ itsu I'm also having the same problem like you, if I increase the frequency). I have tested hundred of diodes, base-collector junctions from different transistors, even bridge rectifiers. Nothing from what I have tested can go under 9-10ns. In contrast I have tested some russian diodes (3-4 types) and 2 of them has shown 10ns DSR effect. This is very strange, as in percents from european-japanese-chinese diodes tested, not even 5% has shown DSR, and for the russian types 50% has shown DSR effect. I don't know why but I believe it has something to do with the technological process of production. Also same type of diode but from different manufacturers has shown different reactions: 1n5406. So more testing/searching has to be done. I'm currently testing the circuit attached (tested on overunity research also). The source of inspiration for this one I think is the document also attached.
Mihai
PS My driver for the nanopulser it's looking like the 3rd attachment. Any comment will be welcomed.
Mihai
verpies
Quote from: mihai.isteniuc on December 11, 2012, 04:19:25 PM
The first circuit is my preferable driving method of DSRDs.
I achieved 1200V @ 2ns FWHM to 50Ω load with this driver and the кд204 diode.
Сергей В.
to mihai.isteniuc ПРИВЕТ
Use ferrite core transformer with high magnetic permeability 10000 or more. As much as it's better. Put him on radiator. Use tleflon wire. Add some negative bias voltage on DSRD cathode via RF choke 100-300uH to sharpen Nano-Pulses. Use high speed driver. Try several КД226 DSRD in parallel and if you want very high voltage in series. DSRD HV capacitors is best mica. Use shortest thick wires. Use good ground !!
Some tests by Papuas on pictures.
ps. You can trigger DSRD effect in picosec domain but you need to go on coaxial transmisson lines and magnetic compression circuitry. If you have High-Tech Vector Analizer go for it. If not forget picosec-pulses!! Dallu used Nano-Pulses !!
Удачи !!
