0 Members and 43 Guests are viewing this topic.
NickZ
  The TK805 is a Russian transistor, providing for an 8 amp output.
While the 2sc5200 is a 230v, 15amp transistor.
  At $1.68 for two of them, they are available, and with free shipping.
  Data sheet on the 2sc5200:
  http://www.datasheets360.com/part/detail/2sc5200/5632587128045190261/?se=ggka&setag=d360&cid=paidsearch&gclid=CMai8JSN6sYCFYsWHwodwNANjQ
  Notice just how many of the WIMA 2000v capacitors he is using under the yoke box.
  And, also notice how Ruslan will not disconnect the Kacher fuse while running a full 4000w load. Why is that???
As that is what is supposed to make a difference, compared to just the inductions circuit running by itself.
  He will not show us what we need to see. That makes me wonder. As it's the first thing I would show.
Tomtech29
https://www.youtube.com/watch?v=e3AJ9fy4tB0
2:30
check this transistor
K 1162
driver
TC4459?
I'm not sure if this comes about: to be up to 13 Amp
you're right there are many (hidden sources) as these :wand to search for water
NickZ
  TomTech:
  That part number is not available for specs, but I found this one below, might be the same, or similar.
  http://pdf1.alldatasheet.com/datasheet-pdf/view/246582/RENESAS/2SK1162-E.html
   I am a water diviner, as well.  I've located and have drilled many wells, and all of them gave great results.
   The rods are the antenna, you become the device...
   These subtle currents are an example some of the frequencies that science can't measure, so they disregard them, as not even existing. Although there may now be ways to register the same or at least somewhat similar effects, using electronics.
   Although we've come a long ways....We still have a long ways to go.
SolarLab
F.Y.I.
3D EM Helical Coil (antenna):
https://www.youtube.com/watch?v=bByO4XQtOKc
Visualization with Sine wave input (open ended):
   - surface Electric Field;
   - horizontal E-Field & Traveling Wave;
  -  vertical E-Field  & Traveling Wave;
   - axial E-Field;
   - surface E-Field (normal component);
  [circular polarization is evident].
EM Field around a Helical Coil (antenna):
https://www.youtube.com/watch?v=TYShKQbKh0U
https://www.youtube.com/watch?v=2x2Rw32Wf4Y
Visualization with short Impulse input (open ended):
Rendered using "Electro Magnetica Numerica"
Demo version available:
http://www.3wells-computing.com/index.php/en/
Traveling Wave Tube (TWT) Design/Simulation example:
{using CST Studio Suite}
https://www.youtube.com/watch?t=11&v=kZxtz9Di2ZQ
Maybe modify a scenario similar to this approach for use in developing FE/CE device characteristics?
fin...
Grumage
Quote from: NickZ on July 20, 2015, 01:02:19 PM
  TomTech:
Dear Nick.
I'm with you 100 % !!
I started my working career as an apprentice electrician for the local Water company. Part of the apprenticeship was spent with all the different departments. I was actually shown how to Dowse for underground mains. Conventional equipment was useless with an Asbestos or any other non ferrous material in use back then.
They even had a very expensive set of rods that had a sample of several different materials on springs, you just drew that into your hand and away !! For the most part a couple of pieces of fence wire did the same job !!   ;)
Cheers Grum
