0 Members and 266 Guests are viewing this topic.
URFA
Quote from: NickZ on July 25, 2015, 07:07:32 PM
  quote from Geo:
  "The only thing I am missing now from the First Akula Device is to know how preciesly the 28T wires are connected thru out the output
coil."
         end quote.
   What I see, is that one end of the 28 turns coil is connected to the full bridge rectifier, and the other end of the 28t coil is open, up in the air.
  Sorry for the blurry picture,  was the best I could do.
Hi, Geo and NickZ.
If you can find out the 28T wire where to connect believe that you can solve 90% Akula's device and Ruslan's device.in my opinion this is the missing piece of puzzle.You're right NickZ, is that one end of the 28T coil is connected to the full bridge rectifier But the other end of the 28T coil not is open.Connected to a cable,the color of the cable gray so we the not see.Look carefully.
These are my thoughts. Ruslan's hiding something, and this is a minor detail. but the device will not work without this detail.Maybe there's another detail.
Ibrahim
DA1
 Hi NickZ   hi everyone,
สวัสดี nickz  และ ทุกๆท่าน
My Videos
It's on my facebook
มันอยู่ใน facebook  ของผม
https://www.facebook.com/engineer.org
Thank You
Dan (da1)
magpwr
Quote from: URFA on July 25, 2015, 09:02:02 PM
Hi, Geo and NickZ.
Ibrahim
hi URFA and Geo,
It's been a long time since i heard from you URFA.
This is my attached screenshot to show the clear connection from 28turns to negative output of the rectifier block at 2:38 into video.
The negative is the counterpoise in this video since there is no Earth.
I do know Akula is using 1/3 resonance/harmonics eg:55khz for low frequency would be 165khz for the higher frequency for the older video.But i can't advise if he is using the same frequency for this video.
Using scope freezing the 55khz sinewave as generated from signal generator as example then inject higher frequency 165khz this time making higher frequency smaller in amplitude and time base.
There is no shifting of horz position in scope at all.
I have attached a screenshot FG->scope one of the example:55khz &165khz to show how this can be easily achieved.Akula did mention about alignment of the 2 waveform which is important.
This was mentioned by Akula in one of the Wesley translated video.
If you observe carefully base on the attached-Edited Akula circuit diagram i have drawn a red line which was edited out from circuit.This shows that Akula did edit to prevent any successful replication.
There is a standalone L/C circuit and a tesla coil on smaller pvc pipe in the middle which is not shown in diagram.There is a connection of thin wire from tesla coil to the Aluminum tape or foil at the top which is serving as top load and also serve to lower the frequency of the tesla coil.
My believe this L/C coil in the middle needs to be resonating freely (just picture this like a flywheel generator which built up momentum) this is likely running at assume 165khz which is 3 times of the input frequency from pwm circuit.
You wil notice there is sufficient spacing given between outer pvc pipe and inner pvc pipe.
In the old device L/C coil and tesla coil is lump together but in the new device the tesla coil is separated from the multilayer coil and using only the Antenna which is using outer shield of coaxial cable in order to maximize the surface area hence increasing the skin effect.
My circuit with snubber seems to be drawing 5Amps.Later i will be removing the snubber since i am using 1200volts IGBT.The snubber does seems to generate heat which is lowing the  efficiency
which is meant to protect lower voltage IGBT 600volts.
In the commercial induction heater 220volts 2000watt which i have reverse engineered driver stage few months ago there isn't any snubber circuit.
Latest update for Sunday-
I have made a small error in my old snubber circuit which is consist of UF5408 andUF5408 in parallel with 5.1Ohms 2watt and series with 4.7nf 3KV changed to 2.2nf 6000volts to drain.
This diode marked red need to be reversed Cathode connected to supply ground.
I have attached a photo of screen of waveform across 28turns now.Refer to last 2 images.
I have also attached photo of small 2.2nf 2kv which we should not used unless you wanna see sparks.Thank goodness no IGBT was harmed.
This time the current consumption is mere 2.8Amps x 13.8volts .But without snubber circuit it's mere 1.9Amps but i prefer the waveform with the snubber. :D
AlienGrey
Hi magpower, this circuit, have you got any data on this circuit ? if you look tin the center of the coil it has no value `any idea on it's size and value ect and how to wind the coil ? or a pointer please.
also the other out of focus circuit isn't much use ;) but nice effort.
RegardsAlien
