0 Members and 345 Guests are viewing this topic.
T-1000
Quote from: Dog-One on July 28, 2015, 06:17:36 AM
This part is still a little disconcerting for me.  If the frequency changes, then it's no longer in the 1 to 100 ratio.  Seems to me this would kill the effect we are after.  Have you found any more information that would explain the derivation of this ratio?  How it was found and what its actual purpose is?
The ratios 1:50 1:60 and 1:100 still blend on resonant harmonics. And the purpose of using high harmonics is to bring frequency into kHz range for induction heater circuit.
With changing loads I assume you will need to tune system for maximum load first so when smaller load is applied the output power will be lower due a bit out of tune.  Just the moment when the Tesla coil driver is fired is still on same position in wave no matter how frequency shifts.
T-1000
Quote from: AlienGrey on July 28, 2015, 07:41:05 AM
Why you call it induction heater
The series resonance is making lots of amps in the coil which cause to heat any metallic object on it due induced losses from Eddy currents. This type of circuit is mainly used in induction heater cooking appliances so the naming is obvious.. :)
John.K1
Hi Guys,  I have got my current sense transformers today, so I am gonna wire it with my microcontroler.  Dog- what resistor value you use to shunt it?
Can somebody explain me please how that Push-pul transformer actually works? Ruslan said it is the part where magic happens as you phase there your current and voltage.  I am thinking a bit different way now. Ruslan many times point to how fast capacitor charge from Tesla. The problem is we can't drain capacitor and at the same time to charge it. Is possible that push pull transformer works here something like the switch or blocker- like magnetic amplifier?  DC voltage controls the AC current flow.  When Tesla fire- it charge the cap and at the same time  DC part blocks the output from that cap,   etc?...
NickZ
  Previously Ruslan had mentioned that the running frequency could not vary more than 100khz.  I didn't study the video to see if it changed any more than that when placing the additional bulbs.  So, is the PLL actually holding the frequency within 100khz, or not?
Dog-One
Quote from: John.K1 on July 28, 2015, 09:03:26 AM
I started with 100 ohm and if by some magic the current goes way up (self runs), I'll add another resistor in parallel to bring the reading back on scale.  For the moment I just need a clean 0-5 volt reading for the input of the micro-controller.  One hundred ohms work very well for the oscilloscope which I needed to get the tuning capacitors set correctly.
I have noticed something counter to what T-1000 is saying by way of experimenting...
When you have maximum amplitude sine wave current flowing through the induction heater coil, you can place a steel screw driver into the tube.  The screw driver heats up no problem.  When you do this, the amplitude coming out of the current sense transformer drops by about 30-50 %.  No matter how much retuning you do (frequency changes and capacitor changes), you can only get this amplitude back up by about 10%.  So clearly the resonant energy gets transformed into heat.  Whether this holds true when you increase the load on the grenade coil, I can't say for sure yet.  It does have me wondering about the effectiveness of a PLL.  At the moment it appears sticking to a locked frequency regardless of load would make more sense.  You can adjust frequency all you want and still not get anywhere close to the original tuned amplitude.  In an actual running system, you can only change frequency dynamically, you can't change the capacitors.  So thinking ahead a little, leads me to believe you do not want to tune this device under no-load conditions.  Better to tune it with the load you expect to run at, that way the capacitor values are optimal and the frequency can be held constant.  Ideally, you want the system to become better tuned the more load you put on it, not the opposite.
As LC circuits go, this is a pretty high Q device which means the margin for error is very narrow.  You need to be in this narrow band or the resonance is gone.
