0 Members and 44 Guests are viewing this topic.
NickZ
  Guys:
  That diagram above is not what Akula had used in his first self runner. Just look at how the bulbs are all connected up.
There is no physical wired connection to those bulbs, as is shown in that diagram. No earth ground in the diagram either, many other points as well.
  The inductor wound over the bigger output coil is not 7 turns, but 12, or twice 12 turns. The feedback coil is 12 turns, not 20.  Don't believe me?  Just count them.
   Also, if you bother to actually count all the coiled turns you'll see that that diagram does not represent what Akula has shown in the video.  Nor is that diagram representing the driver circuit to his first self runner.
  IF Akula made that diagram, he didn't show the device that represent what is being shown on that diagram.
Hoppy
Quote from: NickZ on July 29, 2015, 09:43:12 AM
  Guys:
  Really, you can try to use the above diagram, but as mentioned it is ALL WRONG. Just look at how the bulbs are all connected up.
There is no physical wired connection to those bulbs, as is shown in that diagram. No ground, Many other points as well.
The inductor is not 7 turns, but 12, or twice 12 turns. The feedback coil is 12 turns, not 20.  Don't believe me?  Just count them.
   Also, if you bother to actually count all the coiled turns you'll see that that diagram does not represent what Akula has shown in the video.  There are not 6 fets, either.
  IF Akula made that diagram, he didn't build that device as is shown on that diagram.
Nick,
C,mon, Akula is not going to hand it to us on plate, any more than Ruslan is and is most unlikely to show a real worker in detail on video. Mags hunch is that the early circuit schematics from Akula may be closer to being workers than anything else published. Experiment with different turns counts and numbers of fets using the interconnections shown. There are many variables to play with. Also, given that we really do not know the modus-operandi, turns count may not be that critical.
Tomtech29
quote:
"I got to ask, do you all think there is some magic behind using the push-pull driver?
Unfortunately  personally I have still doubts because you did not answer the question:
-for which the system is not powered directly from the mains or by a transformer 50Hz.?
-why and for what purpose so much effort to this driver?
-what benefits when we adjust the phase shift?
-which goes on for less filling of shorter pulses Akula an example where the signal is not 50% to 50%?
-Why the push-pull effect is used bell rings Do you know what are the benefits?
This is not magic but(ignorance) gently not know all the parameters.
would replace many of these facts is that let's say it's a different system having a similar effect it will no longer Replication.
I repeat that every idea is a good one and helping to grow!
which you will have a power rating by the an amplifier to compare with the current converter?
NickZ
   But we do know what we can see. And, what we can see is not that anything like any of the diagrams.
   So, how would you go about trying to replicate something that is not being fully disclosed. Using diagrams that aren't representative of the actual devices? And which are made for disinformation purposes.
  At least Geo build same driver as was used,  and may have the actual schematic for it.
Hoppy
Quote from: NickZ on July 29, 2015, 10:19:28 AM
Purely by guesswork and perhaps a bit of intuition, basically what we are doing now.  :(
JB kept things up his sleeve for years, speaking in riddles but in the end his technology all boiled down to the effects of battery desulfation and little else. Hopefully, this Akula, Ruslan and Kapanadze stuff will turn out more interesting.
