0 Members and 93 Guests are viewing this topic.
Tomtech29
"magpwr"
This image of you is the 28 winding 2.44Kv is no varistor
whether the image of the second channel of 3 windings is identical interests me peaks?
and how it will affect the attenuation of these rings in a heater?
because if their absence will help to improve productivity will it looked like almost sinusoidal  ;)
AlienGrey
Push Pull is an audio amplifier where a totem poll effect is used high side and low side, both upper and lover devices are biased on with a linear crossing over effect that is used to give you a LINEAR SINE  wave, and not a square wave.
Remember the old rule about sine wave, are you all building a class AB audio amplifier NOW ?
magpwr
Quote from: Tomtech29 on July 29, 2015, 10:52:53 AM
"magpwr"
hi Tomtech29,
It's around 320Vpp across 3.5 turns 6 mm sq.
It will be sinusoidal once we combine with a capacitor after 3 turns and running at resonance  because we have never implemented interrupter to PWM circuit before.
No changes if it's just PWM OR PLL circuit.
As mentioned earlier i am curious myself as i know how a waveform would look like with interrupter with my version of tesla coil with spacing between winding.
But i do not know how a waveform would look like across capacitor at resonance using interrupter with TL494 as i have not done this before.
Interrupter circuit should  be running around 4 ..7times or more than the TL494 manual preset frequency which also running at resonance for a given setup.
pulse width can be anywhere from 200ns....2us for the interrupter which running way below 50% duty.
Even a additional TL494 can be turned into interrupter circuit for TL494.
Got to rest...
NickZ
  Although there are some interesting ideas about drivers and coil winding and such, everyone is on their own here now, as there are no two replications that are the same, nor any that are working and can run themselves, so far.
  As you can see, Ruslan is back to the grenade/yoke devices, and has improved the output sufficiently to light up 4000 watts worth of bulbs.  Unfortunately there is no schematic, nor a clear understanding of it's working principal, nor exactly how the different driver circuits function. So, it's not really something that can be replicated, at this time. And all previous Akula diagrams are not correct, either.
  So, intuition is needed, huh?  I fear that even our intuition is not working very well, so far, either.
  Might be a continued case of the blind leading the blind.
Hoppy
Quote from: NickZ on July 29, 2015, 12:51:44 PM
You said it Nick!
