0 Members and 220 Guests are viewing this topic.
John.K1
T-1000  And what you say about Mishin's  "coil capacitor"?
John.K1
Quote from: NickZ on August 04, 2015, 02:08:32 PM
  But, normally HV pulses won't light higher wattage bulbs, like is being shown. Possibly even higher than just 60 watts.
And much less, feed some current back to the input side to self run itself.
Nick, I will be very happy to have 2W self tun at the beginning ;)
Hoppy
Nick,
It depends on how powerful the pulses are. High power pulses, driving high powered bulbs needs a high powered supply source.
ariovaldo
Quote from: John.K1 on August 04, 2015, 01:41:44 PM
The only problem with that is you have to ramp your signal extremely fast so the pulse doesn't reach the other end of the wire before you switch to the load? Or in other way- you charge (HV) the special matterial (Al+Fe)  to the state of saturation before it change to the current. Than you switch to load and give it a small impulse to get electrons to flow on the surface as an current. - If I am not wrong.
I posted this link just to make easy to understand that is possible to isolate the load from the source easily. For small projects, we can use small relays working " vibrating", that is put the normal closed contact in series with the coil.
This can be done using IGBT's with the correct set of protections.
T-1000
Quote from: John.K1 on August 04, 2015, 02:17:32 PM
Wish I could remember video with experiment he shown it running.. mini TPU with LEDs?
Probably it is same thing just with as we had when you have 2 open ended coils and each is as capacitor plate having inductive element amplified.
Now if you get back and take another look on akula/Ruslan device this stuff should make more sense... :)
