0 Members and 67 Guests are viewing this topic.
Bat1Robin2
How is collecting Bemf energy from a charged up coil  different than collecting energy from a charged up capacitor. (one uses L the other uses C) The energy from the magnetic field build up in the coil will be only equal to the energy used to charge it. Somehow we are suppose to believe that energy will just decide to jump in and join the collapsing field. This is why Bidini  school girl type stuff has failed at overunity and only use-full to restore battery plates. The only difference is that a cap will go to whatever current it possible can during discharge and a coil will go to whatever voltage it possible can during the discharge. But energy in the discharge always slightly less than needed to charge up. Therefore when a coil discharges in bemf mode it can shock us due to the spike in HV making the appearance of something shocking but it is normal operation. No one notices anything special when a capacitor discharges with a large current spike because no one is shocked.  Claims that during the bemf collapse  of a coil will somehow run cold and pull in thermal energy into the collapse are somewhat hard to believe.  Claiming that it can pull in energy from the vacuum (which is defined as nothing) is even harder to believe.  Experiments shows us the truth every time. Setup a simple Bidini circuit and collect bemf. it simple is not overunity, nothing runs cold. The only thing i find to be cold is the cold truth than the event emits regular EM from the event as a loss. The collapsing event seems powerful and energetic just like a sledge hammer hitting the anvil. But every bit of energy in the bang was paid for in full to raise and push the hammer and there will be no little smurfs from the vacuum wearing scalar wave shoes to help. Even tho the bang is isolated in time from the loading process it is far from free. In fact energy from all events and actions cause leaks into the abyss of deep space as EM escapes at speed of light to come to a equilibrium with the 3 degrees above absolute zero of deep space. Nelson claims only high efficiency not overunity in his 1 year old video. What about his newest anyone know what exactly he is claiming? 93%??  And whats this talk about charging capacitors instantly, all caps are charged instantly without restrictive losses. RC time constant is proof in the math. So where do you find the smurf with scalar wave shoes to charge your capacitors without a source this is the real question. Jargen yes indeed. Everytime someone says energy from the vacuum just think of smurfs. If they say zero point energy think of 0=1. And output isolated from input think of hammer falling on anvil.
magpwr
hi everyone,
I have assembled the circuit in virtual environment to test if the circuit works as provided by Nelsonrochaa or if it does consume below "10mA" using 9volts DC as source while producing more than
380volts DC from step up transformer.
The current consumption does seems to tally with the youtube video. :D :D :D .This is definitely good news.
I have attached 2 screenshot part 1 without bulb and part2 with bulb switched on.
I was more interested in the HV production using low current below ""10mA"".Let's assume it's around 10mA for the actual assembled circuit.Power =9 x 0.01 =0.09Watts
For comparison i do have a disposal camera circuit as one of my HV generator.It uses 1xAAA battery 1.5volts at 80mA under no output load or capacitor involved condition  :) .
Power =1.5 x 0.08=0.12Watts
Spark gap would also be more feasible provided if it's around 470volts....1000....1500volts volts at transformer output.I think it's better than to charge a pulse capacitor then use it again for nanosecond pulsing purpose.
Ok i was being rude to Nelson few days back.I've regretted what i have said.My sincere apology to you Nelson.
AlienGrey
Bat1Robin2
                Are you taking the xxxx! why not an orange or a monkey nut ?   a capacitor has loss, however a coil has a fly back and a gain from the iron core and the winding, Do you paint by numbers by any chance when your not on here ? ?
Hoppy
Hi magpwr,
Thanks for your simulations on the LC oscillator.
I'm hoping that Nelson can tell us where in the circuit he connected his lamp load labelled 'load' on his demo board. This output was not shown on the circuit diagram he posted. Nelson was making the point that a bulb connected to this output did not dim when the HV capacitor was shorted, thus according to Nelson, showing that the capacitor was charged by displacement current, not mass current. Its not possible for us to verify this without the connection details. As it stands, your simulation shows a circuit operating conventionally.
AlienGrey
Aliengrey:
   What I mentioned sounds like jargon to you, that's not what's happening?  I don't know what you mean by that, as the quote above is NOT something that I came up with.  In any case,  thanks for your evaluation.
   Perhaps you'd like to show us how you make a self runner and separate the input from the output, simple as that.  Are you going to show us how it's done, or waiting for someone to follow your jargon?
  As there are no schematics showing how this isolation tactic is properly done, I'll wait and see if someone else will try it out, first, and report back.  I've got other things going on at my work bench, for now.
Yes very funny Americans have a nack !  if i was to do that i would be responsable if it didn't work and also i would have a problem with the Oil companys if i did, so NO! i think i will lwave that to others and if it's a self starter or not who cares ? as long as i can warm my hands in the winter thats ok with me. So are you after making them as a business then ????? cus that's the onlyt way people will buy them !
