0 Members and 141 Guests are viewing this topic.
Hoppy
Quote from: nelsonrochaa on August 10, 2015, 05:12:21 AM
Hi ,
I will say a last time :
People should continue work in their experiments.  The misunderstandings it not happen again .
Nelson,
I've got your message loud and clear, thanks.
Cheerio
T-1000
Hi ,
Understood, then http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg458475/#msg458475 still apply. That wasted 5 forum pages and time with 0 positive outcome...
nelsonrochaa
Hoppy
Quote from: NickZ on August 09, 2015, 06:44:26 PM
  Gyula:
  Here is a picture of the PS. It was a $15 el cheapo from Amazon, plus $5 shipping.
  The unit says,  Model: Lithua -240W. AC input 110v to 220v. DC output: 24v, 10 amps.
  But, on the box it came in it says, SUPERNIGHT  LED DRIVER. SC-200, 240w. OUTPUT: 5v, 12v, 24v, 36v, 48v. DC.
  Thanks for any help, I just don't want to burn something up.
  Sorry for such a big picture, I could not resize it.
   Here's the link from Amazon.com:
   http://www.ebay.com/itm/TL494-KA7500-DC-9V-25V-Driver-Board-DC-DC-Converter-Inverter-Boost-Module-PWM/181449170972?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29981%26meid%3D30dc72264dca4a97a16b1bc6190c0221%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D141408846492
Nick,
I purchased a couple of these cheapo PSU's and noticed that one of the packages was not appropriate to the product. Its probable that they have just used any handy box. I'm fairly sure that all three outputs will be 24V, as most of this type of PSU have paralleled outputs. All you need to do is measure them with a meter. The adjustment pot on the LHS is for fine tuning the output voltage. Otherwise, its plug & play.
gyulasun
  Gyula:
  http://tinyurl.com/nej74sz
Hi Nick,
Very likely your PS has a 24V DC output only,  as Hoppy wrote and the potmeter allows a fine voltage adjustment, maybe  +/- 0.5V or so
around the 24V DC output.  So you can take out max 10A at 24V when your AC input is between 110V to 220V.
I found a similar PS at ebay http://tinyurl.com/oo4do6z   where you have to choose the output voltage and amper ratings before
ordering (a single output voltage at a current you prefer) while the offer indicates outputs of 5V 12V 24V 36V and 48V and several
output currents.  I show a picture below, taken from the above ebay page how the connecting terminals meant.
Very probable that your PS has similar terminals (i.e. paralleled as the red rectangles show for the DC outputs).
(Your Amazon link above is an ebay offer on a PWM boost module, you surely noticed that already.
I prefer using http://tinyurl.com/  when a url link is very long, making the line lengths extreme long horizontally on this forum).
So just input your AC mains voltage and check the DC output voltage and turn the potmeter on the right to see
what lower and upper limits the 24V changes  (say you find from 23.4V to 24.5V, etc).
Gyula
PS I assume Windows 10 also has the built-in picture editor,  Paint.  You can use it easily too for resizing pictures
which are higher in pixel number than 850, horizontally.  Pictures higher than that in pixel number will cause
the forum page wider and wider, forcing you and everybody scroll horizontally to the right to read the ends of the text lines.
In Paint you can resize i.e. also reduce any picture because it can show both the horizontal and vertical  pixel numbers.
Perhaps Hoppy can edit his post above and replace your ebay link he quoted with this simple url http://tinyurl.com/nej74sz
then this page will be resized also to a normal size.
