CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
Analysing of Bessler's Clues 04.
< Relation between the Cross and the Diameter >
- the increasing of the cross causes the weight to reduce its area of movement
- by increasing the diameter of the wheel, it also expand up the area of maneuver for the weights
- so the cross and diameter work hand-in-hand to increase the power of the wheel
helloha
http://youtu.be/t03yeg9ilMY
a computer animation of hourglass with double turbine attached near the edge of hourglass
helloha
Algodoo index XXVI. an outlet control to determine narrower or wider flow of fluid with turbine attached
helloha
Analysing of Bessler's Clues 05.
< Reduce the size of weight (also reduce the mass of weight) vs Increase the diameter of wheel >
- if increasing the number of cross will restrict the movement of the weight, there is an alternative (beside increasing the diameter
of wheel) to expand up the area of the weight, reduce the size of the weight (which in turn will also reduce the mass)
- also in other words, when increase the diameter of wheel, but retain the same number of cross, will result in increasing the mass
and size of weight
- any clue to indicate any changes in the mass of weight
"Who can make a pound-weight rise as 4 ounces fall, or 4 pounds rise as 16 ounces fall."
- the example of a pound weight and/or 4 pounds might indicate that possiblity of weight changes in the mass, which also result
in size changes
take note: using mass of weight, instead of the weight of weight (sound funny)
helloha
Analysing of Bessler's Clues 06.
< Possible existence of Two type of Weights >
- refer to the image, highlight the keywords to indicate the 2 weights
syadrehtonoputihctaplliw,secnetnesehtfogninaemehtfonoitaterpretniehtnoekatsimedami
