CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
rc3po
A gravity wheel using the leverage of weight from gravity would not work. You would have to calculate the centrifugal force of the spinning wheel, which would tend to throw the weight out, cancelling the force of gravity trying to pull the weight in.
I was thinking about a similar wheel using solenoids to control the movement of the weights, controlled by a couple of Hall-Effect switches.
I haven't tried it yet.
helloha
Analysing of Bessler's Clues 07.
< the Light weight, the Heavy Weight and the Heavier Weight>
- refer to the image, highlight the keywords to indicate the existence of the light and heavy weight
forest
still there ? I thought it was explained in other thread in this forum  ?
helloha
Analysing of Bessler's Clues 08.
< the 1:4 Ratio >
- refer to the image, it indicates the mass ratio between the light weight and the heavy
weight
- suspecting the ratio of the weights might be one of the key factors that determine the
RPM of the wheel
helloha
Analysing of Bessler's Clues 09.
< Conflicting Situation regarding the RPM of Gera & Draschwitz >
"The machine's power was directly proportional to its diameter"
"If I arrange to have just one cross-bar in my machine, it revolves very slowly, just as if it
can hardly turn itself at all, but, on the contrary, when I arrange several bars, pulleys and
weights, the machine can revolve much faster."
- if the increased in cross (which also increases the diameter) affect the rotation speed of
the wheel, how come the RPM doesn't seem to have drastic changes between the Gera
Wheel and the Draschwitz Wheel (both running around 50 RPM) ?
