CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
a-XXX XXX V. trying my hands on wm2d, (continue) RPM of wheel affecting the circle rolling down the slope
helloha
a-XXX XXX VI. trying my hands on wm2d, a trick to make a low rpm wheel seems to appear as fast rpm wheel
helloha
Analysing of Bessler's Clues 13.
< Quarter, an alternate meaning >
"He will be called a great craftsman, who can easily/lightly throw a heavy thing high, if one pound falls a quarter,
it shoots four pounds, four quarters high."
- quarter is commonly known for its numerical or mathematical roles
- but it is also used to represent a specific district or section, or a place of residence
Vortex1
Perhaps take a look at this (the video in post 643)
http://www.overunity.com/14565/the-bessler-wheel-mystery-solved/msg404406/#msg404406
In the end, I doubt that it will be balls rolling on their own, as that seems way too sluggish in most of the simulations I have seen, but a combination of springs counter balancing weights, working against centrifugal force in a timed manner. Oscillation of the spring / weight assembly may also be a factor.
helloha
Analysing of Bessler's Clues 14.
< A Heavy Wheel ? >
"I then stopped the wheel with much difficulty, holding on to the circumference with both hands. An attempt to stop it suddenly would raise a man from the ground.
Having stopped it in this manner, it remained stationary... I commenced the movement very gently to see if it would of itself regain its former rapidity, which I doubted, believing that it only preserved for a long time the impetus of the impulse first
communicated. But to my astonishment I observed that the rapidity of the wheel augmented
little by little until it had made two turns, and then it regained its former speed, until I
observed by my watch that it made the same twenty-six turns a minute as before, when
acting freely." - eyewitness account
- refer to image, possible indication that the wheel is heavy by using a comparison to the
characteristic of flywheel
"If I arrange to have just one cross-bar in the machine, it revolves very slowly, just as if it
can hardly turn itself at all, but, on the contrary, when I arrange several bars, pulleys and
weights, the machine can revolve much faster, and throw Wagner's calculations clean out
of the window!"
- more cross/crossbars, more weights
- so, when there is more weights, the heavier the wheel
