CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
Analysing of Bessler's Clues 30.
< 3 Rules of Positioning the Swinging Weight.
   Rule no 1. Swing and Stay, don't swing back >
"each child can swing (or you might call it "step" as it uses a club as a "leg") from the top of one broken column to the top of the next broken column by positioning his heavy club on the ground between the two close columns and holding on to the handle end to swing over to the top of the next column."
- child, aka swinging weight, swing from 'top' of column to next 'top' of column
- infomation that can be extracted from the above
1. the weight stay at the top, or a particular position
2. the weight did not swing back
- refer to image for graphical presentation
helloha
Analysing of Bessler's Clues 31.
   Rule no 2. Farther from axle, nearer to axle >
"a work of this kind of craftsmanship has, at its basis of motion, many separate pieces of lead. These come in pairs, such that as one of them takes up an outer position, the other takes up a position nearer the axle. Later, they swap places, and so they go on and on changing places all the time"
ARMCORTEX
Its my belief that you can do this, and implement a precession
It's also my belief that you are wrong when you say long arms can't be used
You have to move the weights , both scenario have advantage, if you engineer right.
The weak point of this designs, you need 1 way bearing, big ones, on well suite machine
helloha
Analysing of Bessler's Clues 32.
   Rule no 3. Right angles to axis >
"one or other of them must apply its weight at right angles to the axis, which in its turn must also move"
- 'one or other' indicates not all of the weights are required to be at right angles to axis at the same time
helloha
Analysing of Bessler's Clues 33.
< Shape of "Swinging Weight and Rolling Weight" vs "Child and Club" >
- this is more of a refresher topic, just linking up the weights to the "child and club"
- refer to the related topic
1. The Basic Shape of the Weights
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg406374/#msg406374
2. A "Child & Club" Interpretation of Bessler Wheel
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg405229/#msg405229
