Theory of over unity, is the theory of nothing - or less.
Started by Low-Q, September 23, 2012, 11:02:17 AM
Low-Q
Quote from: forest on September 23, 2012, 02:04:40 PM
Sorry. I don't understand.  :o Normal behaviour is that : you push boat and boat pushes you in opposite direction. Then to push more you have to move forward to get boat which is escaping and then push it more.
Unity boat : you push boat and it doesn't push you back but you still have to catch boat escaping you.
OU boat : you push boat and boat push you in the same direction so you are always in the same place relative to boat and can push it again.
Super OU boat : you push boat and boat push you in the direction of movement so you again collide with boat and push it harder then boat push you harder and both you and boat accelerate in the direction of movement.
That's all. There is always gain in every oscillating system but the symmetry law cause it to balance any power usage. By differentiation due to direction of mevement we got an ordinary system below unity...
Normal behaviour is straight forward; The boat will force my hand back as much as the boat is forced forward.
However, at unity, the boat require 0 energy to start moving. That means it will be no force (I will never know if I touched it or not), only acceleration. 0 force x acceleration = 0 energy. You can't feel anything. Over unity boat; negative force x acceleration = negative energy. To achieve negative energy, the mass must be negative. However, both examples of the unity and overunity boat is fictive incidents, so there is actually no way we can confirm how it works in practice. Only theory can "confirm" the outcome.
Vidar
forest
You take it wrongly! You are assuming that normal situation is normal and ou is strange negative energy, while (after years of analysing) I'm convinced that normal situation is due to working governor aka negative energy which is always opposite to applied force = Newton third law. Completly opposite as you see !
It has to work that way to build stable world but pure existence of explosive materials is proof that we can work around the Newton third law.
