Seven times more energy output than input: Power Multiplier Device
Started by Russell Lee, October 04, 2012, 03:20:25 PM
Russell Lee
 Neo-X,
  Information added to the squidoo site shows that if there are ten of these simple mechanisms charging into the same battery bank there will be seventy 30 second periods of charging, and 10 of drawing out. That is 35 minutes of charging, and 5 minutes of drawing out.  Whenever there is one descending there will be at least two others descending at the same time charging more into the battery than the one descending is drawing out (because as it ascends it also is generating energy to the battery).  Regards, Russell Lee
Quote from: Neo-X on October 19, 2012, 05:50:14 AM
Okey lets check this theory if this was true using calculation and using the above example. We can say that the input power was the power to move the 500lbs weight on the top (lets say 10meters) for 30second and the output power was the power excerted by gravity to move the weight downward by 10meters for 3minutes.
Input Time = 30s
Output Time = 3x60= 180s
Mass = 500lbs = 226.79kg
Distance = 10m
Work = M x G x D
= 226.79 x 9.8 x 10
= 22225.42 joules
Input Power= W x Ti
= 22225.42 x 30
= 666762.6 watts
Output Power = W x To
= 22225.42 x 180
= 4000575.6 watts
Excess Power = Po - Pi
= 4000575.6 - 666762.6
= 3,333,813 watts
very simple calculation :)
Russell Lee
  There are two FE generators on this site, please do not confuse the Pinwheel Generator with the Power Multiplier Device. Thank you, Russell Lee
Quote from: Russell Lee on October 04, 2012, 03:20:25 PM
www.squidoo.com/pinwheelgenerator   This generator produces at least seven times the energy than it needs to run.
Russell Lee
 *Important* As the weight/bracket assembly is climbing the chain it still has it's weight hanging on the chain pulling it down as it climbs, still generating a full charge into the battery. This replaces the lion's share of the energy the small motor is pulling out of the battery to use for it's purpose.  This is how there is excess 'free to use' energy being generated. Regared, Russell Lee
Low-Q
How many times is it neccessary to remind you folks that gravity cannot do work?
Gravity is only a permanent force. In order to get energy out of it, that force must alternate naturally - which it doesn't. It is constant.
A weight must be applied less gravity when it rise, and applied more gravity when it falls. This is the only way to get energy out of gravity and weights. If gravity doesn't change (Which it doesn't), the weight cannot provide any useful work.
Vidar
ingyenenergiagep
"Input Time = 30s
Distance = 10m
Work = M x G x D
= 226.79 x 9.8 x 10
= 22225.42 joules
Input Power= W x Ti
= 22225.42 x 30
= 666762.6 watts
= 22225.42 x 180
= 4000575.6 watts
= 3,333,813 watts"
E= m x g xh
226.79kg x 9,81 x 10m=22248,099J
30s 741,6033W
180s 123,6W
