0 Members and 74 Guests are viewing this topic.
dieter
Hanon,
I've been revisiting your like pole drawing and I begin to understand. It could work in a way similar to the BTT. But I think the outer core must be thinner than the inner core. And the  outer core must be saturated, otherwise the like pole paths may "parallelize" within the outer core and .ignore the inner core. (a rather controversal issue, if such parallelization does exist at all, that I tried to address in the AFA thread)
shadow119g
Hanon:
I will try the duel resistor as soon as I finish my new commutator.
Thanks,
Shadow
From other Planet
dieter
Just a little update. As I said, I will use the soundcard oscilloscope and try to compare input and output on the left and right channel... only problem: the stupid laptop has only a Mono mic in...  >:( .. So I'm kind of stuck here, but there's one interesting observation I made
When I attached a diode to the input source on one pin, expecting to get something halfrectified, then I was getting the following strange output.
It may indicate a 70 to 90° phase shift, your comments are welcome. Connecting a load however did not alter the "shift", but only the voltage or dB, so the wave decreased in height. The whole probe setup was confusing, as the computer seemed to add some volts to the output when connected... Anyway, here's the scope pic, mono. Whatever is negative there doesn't come from the supply, and for a back emf it looks rather unfamilar to me...
hanon
ANOTHER METHOD TO ALTER THE MAGNETIC FIELD OF AN ELECTROMAGNET
As far as we have been discussing we have tried to change the magnetism of the electromagnets by changing the current which circulates along each one. As we know, this system requires a variable resistance, I = V/R . This system is very inefficient because of the heat dissipation in the resistors.
We could also get a variable magnetic field if we change the number of effective turns (N) in the electromagnet.
B = nu·N·I / Length
Suppose that we build a electromagnet with 700 turns with 6 intermediate taps at 600, 500, 400, 300, 200 and 100 turns . If we feed sequentialy to each tap we will get a variable magnetic field in the electromagnet.
This could be got with a proper circuit (as a CD4017 + 555) and some transistors.
I have wonder many times why Figuera used 7 groups of electromagnets and, also,  7 intermediate resistors. Maybe he just drew in that way to clarify the concept but he built it in a different way to skip the heat dissipation... I don´t know
PS: Also I attach another sketch with the electromagnets with like poles facing each other. The swinging back and forth of the two magnetic field will produce a movement of the magnetic lines. When they collide, they are expelled from the core and in this movement the magnetic lines will cut the induced wire. Suppose a pancake coil or many parallel wires in between the two core sides.
In all dynamos and generators induction is done because the induced wire is cut by the magnetic lines. Just some food for  thought...
