NRamaswami
RandyFL:
I used soft iron rods. We need about 60 rods to pack a 2.5 inch plastic tube. air can go through the rods from one end to the other end. so heating may be reduced by convecton. I do not know. Rods do not get overheated when we employ high voltage and much lower amperage in the region of 7 to 10 amps. However if the voltage is less and amperage is more rods do get heated. An open core draws so  much of current that circuit breaker at office rated at 32 amps will cut. At high voltage, the vibration is metal seems to be so fast that it dissipates heat very quickly. But the sound at high voltage is different from sound at low voltage. If the saturation levels are reached Iron will scream but at high voltages iron  does not scream.
I have simply used it the way shown in the Buforn patent last patent as all NS-NS-NS-NS-NS..I have already posted this. At that time I could not get NS-SN-NS to work or NS-NS-SN to work. I found that if we use a square electromagnet to surroundthe iron rod that goes between the two primaries with identcal poles then the secondary would work. But the square must be wound as two CW and two CCW coils serially connected. So in essence you have a small y coil between N and S core as shown in the Figurea drawings. No circuits. Just simple plain connection to the mains.
But the small size of the Y coil does not mean that the wire length or turns is lesser than the two primaries. In fact if you have N-Y-S-Y-N you will have three primary coils and 8 secondary coils although the secondary coils will be far closer to the two primaries and will suffer the maximum magnetic flux. Howard Johnson says that the magnetic flux between identical poles is 3 times higher than the opposite poles. Doug1 has been trying to kick this in to my brain without success for a long time. But the problem is that we need the square electromagnet to surround the secondary core to get the secondary current in that set up. For the opposite pole a staight line works. smaller the y magnet in the NS-NS-NS higher is the magnetic flux encountered and voltage obtained. Same as in the identical pole. But Figuera appears to have used opposite poles only for he says that the set up is free from Lenz law. I have obtained the results only in the opposite pole configurations but I think we can obtain better results in identical pole configurations also but I have not tested.
RandyFL
20 May 14 / 02:32:00
NRamaswami:
Why build the replica of the Figuera when the circuit that Patrick designed works...of course you have to modify the circuit to run exactly as Patrick designed it ( or at least I had to )...
Patrick stated to me that I only needed bar steel ( or whatever its called ) like Woopy used to get it to work... but I couldn't get any electricity from it.... so I went to radio shack and bought a eight dollar ( US ) transformer and reversed it ( step up ) and got 1 volt AC from a 9 volt battery...
Granted...that soft iron is better than steel laminations....but at this stage I just want get to the end product ( asap ).
Namaste
RandyFL
NRamaswami
RandyFL:
I'm not doing any thing right now. Nor interested now. I do not know what others did. Patricks circuit is designed for low voltages and will burn out at high voltages. I have tried at lower voltages and higher amperages and as things did not work moved from lower to higher voltage and got the results I could report.
In fact I imagine that the Al origin reported by Figuera to be earth connections. The secondary in my opinion would also be connected to two earth connections. so we would have Four earth connections and four capacitors just before the earth connections. Kind of 1,2,3 and 4..The Points 1 and 4 would have the maximum differences in voltages. So when you excite the Earth with potential differences through a capacitor like that you can take free electrons from Earth due to potential difference between the earth points is my assumption. But I have not tested it. Nor do I intend to test it for the Voltages are very high and I do not know what would be the resulting currents. But it is a fact that when the secondary Voltage goes up, the secondary amperage goes up even without the earth connections. The old devices are actually far more simpler to replicate than lot of electronics which reduces our ability to increase the voltage and frequency as we wish. You can simply use wires without any electronics to increase voltages and it will work. A run capacitor will work at designated voltages. The wire can withstand the amperage for which it is designed. A spark plug can create the high frequency needed without expensive signal generators. These are devices that were made when electronics that we know of did not exist and so we should be able to do these things easily and cheaply.
As to your question as to why I did what I did, that is what I could understand. I could not understand Electronics at all. So I simply coiled the wires and tested. Not any more testing as it has taken too much of my time..
NRamaswami
Avengers:
Just a thought.. In your three core transformer remove the central core and put there an iron core alone without the coils. Now surround this iron core with the square electromagnet. The secondary would work. Or you need to make all three cores either CW or CCW. Then also secondary will work.
RandyFL
20 May 14 / 07:45:02
Avengers:
How did you test the 555 and the 4017s?
NRamaswami:
Part of Patrick's design isn't intended for high voltages... The other parts are. As I understand the premise for Patrick's design is for the user to achieve freedom from the electrical company not supply the country for electricity... for example my main electrical need is AC, stove and clothes dryer. One single circuit could achieve 120 or 240 volt in the 40 or 20 amp range all achievable with Patrick's design...
Furthermore...even if the Patrick design doesn't achieve over unity we have the solar panel and wind generator to utilize it...
Its up to US to achieve our financial freedom not Governments or other countries...
All the Best
RandyFL
