Cadman
Figuera Spanish Patent # 30378
5 September 1902
In the arrangement of the excitatory magnets and the induced, our generator has some analogy with dynamos...
In the winding of this induced wire, within the magnetic fields, are followed the requirements and practices known today in the construction of dynamos, and we refrain from going into further detail, believing it unnecessary.
marathonman
Came across this circuit and thought some of you might want it.
Happy Figuering!
hanon
Hi all,
Please see this link and the demo video included inside:
http://fuel-freetech.com/
In the 1902 press it is mentioned that the Figuera´s apparatus "comprise a GENERATOR, a MOTOR and a sort of governor or regulator, and the whole apparatus is so simple that a child could work it"  (link to the press clipping)
I think that maybe the working apparatus in 1902 was related with the moving coil patent ( Patent No. 30376 ). We have just focused into the motionless patent (No. 30378) but, maybe, the real  working apparatus was the one based on the moving coil patent.
Patent 30376 in pdf: http://www.alpoma.com/figuera/figuera_30376.pdf
Maybe in 1902 the generator was based on the moving coil system, and, latter, in 1908, Figuera tried to improve it and, then, he moved the fields instead.
In the next link there is a list with 50 different designs for a motor + modified generator:
http://peswiki.com/index.php/Directory:Motor-Generator_Self-Looped_with_Usable_Energy_Left_Over
It is just a thought. Maybe we have overlooked the real important Figuera patent. Comments please !
hanon
Hi,
This is how I think that the winding in patent 30376 (Figuera´s design with rotary coil) might have done . It looks like the "old drum winding" is different to our current concept of drum winding.
forest
what is different ? I thought that drum winding can go in one way only ...  Cadman armature from the previous post with non-movable rotor and a drum with windings and a pulley connected with a ball bearing to the non-movable shaft and a tube connected to that pulley and to the drum . On the second side tube connected to another ball-bearings mounted on shaft, on that tube two sliprings are mounted where cables from drum coil are placed. In simpler prototype bearings could be ommitted.
