hanon
Quote from: forest on June 03, 2014, 04:01:03 AM
what is different ? I thought that drum winding can go in one way only ...  Cadman armature from the previous post with non-movable rotor and a drum with windings and a pulley connected with a ball bearing to the non-movable shaft and a tube connected to that pulley and to the drum . On the second side tube connected to another ball-bearings mounted on shaft, on that tube two sliprings are mounted where cables from drum coil are placed. In simpler prototype bearings could be ommitted.
Quoted text from patent 30376:
"The induced circuit formed by wires coiled in a drum type configuration
rotates around its axis, inside the magnetic fields"
"The inducer or exciter circuit is formed by two series of multiple electromagnets,
motionless them all, and conveniently placed so that each pole of a series will be
at short distance in front of a pole of opposite name in the other series. In the
small separation between the expansions of these electromagnets the induced coils
rotate, dragging, in its turn, the collectors and transmission pulleys."
The drum winding explained in previous post show a wire encircling the whole core. It is not a wire doing loops in between the poles of both electromagnets. With the proposed drum configuration the induced magnetic field is at right angle to the magnetic field from the electromagnets, as shown in the sketch in prior post. I think this could help to cheat Lenz´s effect
stupify12
Hello hanon,
I think the patent which Figuera explain on this quotes really match very well to the High Frequency Alternator/Generator in our term of Nikola Tesla.
quote]"The induced circuit formed by wires coiled in a drum type configuration
rotates around its axis, inside the magnetic fields"[/quote]
The design which I have read from Tesla the Magnetic fields is a Even pair of poles. Tesla start from 16 poles, 32 poles, 64, 128 until to 348 magnetic poles. I know exactly how did Tesla design this kind of machine which He always used to feed his Bifilar Tesla Coil. Tesla used this High Frequency Alternator/Generator which actually produced DC because of the Brush Commutation on this device.
Quote"The inducer or exciter circuit is formed by two series of multiple electromagnets,
This inducer or exciter circuit = Outer Magnetic Fields in the outer rim, it is wound in a Zig Zag style as Tesla showed on his designs, the purpose of Zig Zag is to make the iron poles pass by the 1  wound coil to be alternate North and South, the bigger the diameter the more Magnetic Poles Tesla could achieve. Yeah the outer Magnetic Field are steady and never moves- so we call it motionless.  The drum which rotate- the coils wound on each PIN is only 4 feet so Tesla could  achieve 0.04ohm on each wound Induced/Generating coils.
The way the Induced coils/Generating coils wound are just simply winding in a PIN that go thru the drum. The Induced Coils as per Tesla is only 4 feet = for 1/4 of an ohm as he stated.
Hanon, if your interested to really understand this machine I could give any information I have learned from this machine that I have understand reading from Nikola Tesla.  The drum is like a wheel of a bike or a motor which has grove inside so Tesla could wound a IRON Wire as a Soft Iron Core, then there are PIN which hold that Iron Wire, Tesla then wound the 4 feet Induced Coils on the PIN embracing the drum which is filled with IRON Wire as a Soft Metal Core on the Drum.
Hope this help.
Meow
marathonman
It seems to me that both systems are being disgusted and it is quite distracting. it would be nice if you guys could pic one and go with it instead of bouncing back and fourth. we all know by now he had two different systems one moved and one did not, pick a system that moves the wire or pick the one that varies the flux.
ps. here is the power supply for the Sine Cosine circuit i posted on 1326. by the way that circuit was made with a quad op amp chip OP470GP.
marathonman
Waiting for more iron to build cores so i can begin testing and boy is it expensive. solid iron core are going to be very, very expensive so right now i am using Iron Electrode Strips. i hope this thread didn't die i rather enjoy reading all the wonderful information you guys have provided.
the cheapest wire i found is here.....https://shop.eis-inc.com/sap(bD1lbiZjPTAwMQ==)/bc/bsp/sap/zeis2/index.htm?prod_area=442  the sight is painfully slow though.
Here is the finished Sine Cosine Generator (improved) with the power supply mounted to the board with electrolitic caps installed. sorry the center tap power supply has no 3D model nor does the heat sinks.
Paul-R
Quote from: marathonman on June 11, 2014, 11:56:45 AM
I am not following this thread closely so I may have this wrong -
- but you may want to know that the Bedini people use R60 or R45 gas welding rods, available from suppliers like BOC.
