marathonman
You have to be a complete Moron to back up your stuff on line. WHY! so every Government NSA agent and Hackers can dig through your Sh!t.......SORRY not me fella. to each his own but i back up on site.
I have a new proposal to Figueras Devise . it came to me when i was studying and doodled it down with paint program. can someone please tell me if BEMF will kill this or not. i think the output will not influence the input.
Fernandez
There is no real direction on this thread for an individual to start experimenting. Those that think that core material is of paramount importance are moving in the wrong direction. This post is for those that have been searching for a low cost starting point. You need to start somewhere, here we have 99 pages, and as a joke I can say "we got 99 pages and a starting point aint one".
This all starts with the understanding of magnetic fields of the 3rd order. Every FE unit contains them to some degree. This post serves to introduce you to the concept. No electronics are needed just some coils. Most of you will disagree and will reply with something stupid as if you have any clue what it is your doing.
I do not reply to posts, it is below me, I only provide information. Those that try will learn something new, and be on the right path, those that don't have already decided there path. Lets start..........
Start by creating two coils, these will be called Coil A and Coil B. These coils (cores) are created with 1 1/4 - 1 1/2 PVC.
Coil A will consist of a PVC form roller of about 6 inches. On this you will roll 4 layers of #14 wire. Over the #14 wire you will wrap 4 - 6 turns of #8 wire. Note you can take #14 wire and bundle it together to create a thicker wire. It is important to know that thicker wire has more natural electricity then thinner wire. This to start will be an air core coil.
Coil B will consist of a PVC form roller of about 12". On this you will roll 2 layers of #14 wire. Over this you will roll 6 - 8 turns of #8 wire. Same applies as above, you can make thicker wire.
Connecting the coils:
First, it is important to understand that if Coil A is mounted horizontal then Coil B MUST be vertical and vice verse. The primary in Coil A should not influence Coil B in any way. Best to leave 1 foot distance between the coils to start. Also the primary and secondary of Coil A should not be grounded. Connect the secondary (#8 wire) of Coil A to the primary of Coil B (#14 wire). Remember this is NOT GROUNDED. The secondary of Coil B should be attached to a small load. This can be as simple as a small coil wrapped around a nail to check for magnetism. Also the secondary of Coil B should be grounded.
The primary of Coil A is connected as follows. Connect one side to a 12v battery, you will operate by hand the other side. Tap the terminal of a 12v battery with the other side. We are creating IMPULSES through Coil A. These impulses should be of short duration. Observe the results of the magnetism on Coil B. There is a difference between the impulses of Coil A and that of Coil B. Coil A is impulsed by the current of a battery and Coil B is impulsed by a magnetic field. The impulses from the battery are different from the magnetic field, here is where you need to observe and study. To recap the important last sentence. The impulses created from a battery are DIFFERENT then the impulses originating from magnetic fields. This is the only thing an FE experimenter should concern himself with.
Variations of the above experiment. Add iron to Coil B. To do this visit your local junk yard and get some "tire irons". With a hack saw cut the ends off and you will have good iron for electro-magnetic coils. Fill the inside of Coil B with this iron, re-test and record results of magnetic field. Remove iron and add to Coil A, re-test and record results. Increase the voltage of the primary and re-test. IDEALLY reduce the input voltage, of the primary, for the greatest magnetic effect.
There is enough experimental work here to carry the part-time experimenter for the rest of the year. Let it be known that you are experimenting with magnetic fields of the 3rd Order. These orders continue onward (4th, 5th, 6th ....etc) each with there own effect. An order is created when an ungrounded secondary is connected to the primary of another coil. It is up to YOU to experiment and find your own answers, I simple pointed you in the correct direction (after a lot of BS written here).
In conclusion......... written in one of the patents is a very, very, very small sentence that validates the above experiment. Much like the 'yoke' (y) it has eluded many.
Good luck.
bajac
Fernandez,
Could you post pictures and videos of the device that is working based on the theory you just described? Because of the manner you expressed yourself, I can only assume that you have tested your theory. Otherwise, you would really have issues for calling other people's work BS.
It is my conviction that even if you are correct, you should be respectful with the people in this forum who are working very hard!
Thanks for sharing!
Bajac
Doug1
 I suspect Fernandez is close. Now lets see what becomes of his mental health.
Cadman
Hello again everyone,
Having convinced myself that the 1908 and later patents were based on the standard dynamos of their day, I threw out everything I thought I knew and started all over again.
I obtained a university level textbook on dynamo design published in 1908 and used the information and formulas from that book to create a design spreadsheet for the 1908 patent. Then I used the spreadsheet to create the specifications for a Figuera style generator with a gross output of 19 volt, 25 amp. All iron and electrical losses are included, even the commutator motor and a step-up transformer at 80%. The transformer was included as a loss in case it's use should be needed later.
The physical configuration of the generator is identical to a four pole dynamo except for the induced coils, which are located beneath the field poles instead of evenly spaced around the circumference of the armature. Also the armature does not rotate and there is no commutator for the armature. The induced coils are series connected with two parallel circuits, each one using nearly half of the armature circumference. It is self exciting through a step-up transformer with the field coil current varied by the separately driven commutator shown in the 1908 patent. Maximum field current regulation is via a separate shunt resistance. All iron parts would be insulated laminate construction.
The design results are rather eye opening.
Magnetic reversals per second: 60
Gross output: 19 volt, 25 amp
Net output: 18.6 volts, 10.13 amps
The most significant revelation in my opinion is this. It appears to be impossible to generate the output indicated if the calculated lines cut per wire, were only those lines passing directly through the unmoving induced wire from it's associated field pole. There simply isn't enough surface area per wire with the magnetic densities possible.
This leads me to conclude that the inducing magnetic field must rotate in order for the magnetic lines from every pole to pass through the induced wire each revolution as they do in a normal dynamo. Then the results I came up with would be produced. I believe Hanon posted about this a while back, that the 1908 commutator could produce a rotating field without using a 2 phase input. And didn't Figuera himself mention the egg of Columbus in relation to this device?
Stupify12, are you smiling from ear to ear?
