0 Members and 39 Guests are viewing this topic.
hanon
Hi all,
I have downloaded Visual Analyzer to use my PC sound card as oscilloscope (Visual Analyzer is a freeware program, you just need to use the microphone input in the sound card http://www.sillanumsoft.org/ )
I wanted to test some AC mains voltage because I am using some transformers, 220V to 12V, (building the circuit posted weeks ago by maddann) and the AC safety system of my home fired up.
What should I do to use this program with AC mains? Should I use any kind of device to reduce the voltage and wattage? Thanks in advance
ignacio
Isfex, Re: Inventor Clemente Figuera
por isfex » Vie Oct 31, 2014 9:38 am
Exposes a video, with the resistive divider Clement Figuera for get a pure sine wave, stop eating the head with that item
-- to work on getting, using 360º magnetic field of the electromagnets
ok
Expone un video, con el divisor resistivo de clemente Figuera, obteniendo una onda sinusoidal pura, dejar de comer la cabeza con ese tema y trabajar en obtener el trabajo de los 360º del campo magnético de los electroimanes
http://cacharreo.com.es/foro/viewtopic.php?f=14&t=1059&start=460
hanon
Hi all,
A new video from a guy trying to replicate the VTA. Two side inducer coils with same poles facing each other, and one intermediate induced coil. Any similarity with the 1902 patent???
http://m.youtube.com/watch?v=ZhQgch4L5XY
He just presents a demo. A 3.6 watt bulb is lighting full bright with just 1 watt input
http://www.hyiq.org/Updates/Update?Name=Update%2003-11-14
Doug1
Hannon
  The person in the video could improve the output of his set up 100 fold if he used the same input the way I described. P = I R the current passing the turns of wire is reduced by wire resistance and self induction of the core. If every turn of his driving coil thought it was seeing a 100 times more current then it was, it would produce a magnetic field 100 times stronger using the same amount of input power as he used to power the full length of his primary coil in the video. Think about all the things which effect the creation of the magnetic field including the core and break it down to the scale of a single turn and the amount of core material which the turn of wire encircles.
bajac
Pardon me for going off our topic briefly but I wanted to know if some of you have bought the Bendini SG books. If you did, do you recommend it? Was there anything knew you learned? Before I spend money on it I would like to hear from someone impartial to the energeticforum website.
Can we relate anything in the books to our effort in this thread?
Thanks,
Bajac
