0 Members and 40 Guests are viewing this topic.
jdavidcv
bajac
I just wanted to share the following with you. The Lenz's law refers only to voltages and currents induced by magnetic fields. It does not make sense to use the Lenz's law in systems that use permanent magnets and pulsed electromagnets. When we apply a voltage to a coil and forces it to interact with a permanent magnet of another energized electromagnet, there is no voltage/current induced by a magnetic field, and therefore, Lenz's law does not apply per say. You just have two sources of magnetic fields interacting with attaction or repulsion forces similar to the case experimenting with two permanent magnets. Based on the above, it does not make sense to cite the Lenz's law for systems such as the Lutec shown in the following links:
http://www.rexresearch.com/christie/christie.htm
http://www.free-energy.ws/lutec.html
You can argue that disturbing the magnetic field of an electromagnet changes the inductance of the magnetic circuit and it might be translated as an induced voltage. Nevertheless, for systems such as the above (Lutec) any induced current by the magnetic field may be considered negligible with respect to the current generated by the voltage source connected to the coils.
I also wanted to add that based on the above, the Lenz's law applies to induction motors but not to to synchronous motors. Induction motors operates by applying a voltage to the field coils and inducing a current in the rotor coils. However, in the synchronous motors, voltage is applied to both, the stator and rotor coils. The interaction of the external voltages generated magnetic fields is what produces the torque in sychronous motors.
ignacio
Es imitar un generador convencional, uno Norte el siguiente Sur.
En un generador que tengo (18 huecos) trifásico, 18/3 =6 bobinas por fase, cada una de unas 240 vueltas +o-, 6*240=1440 aproximado. (Los bobinadores lo calculan según tipo de hierro y tamaño). 4 electroimanes = 2 Polos, de unas 200 vueltas cada uno. (No he contado las vueltas, me lo dijo un colega)
Como dices que tienes algunos trastos, al igual tienes algún generador (viejo o roto), se cortan los cables que llegan a las delgas (recolectoras) y  alimentas los electroimanes con el cachivache que tengas, te va a dar una idea de lo demás...  Puedes con el voltímetro medir, para unir terminales... (Aprovechando a su vez el bobinado de excitatriz, si lo tiene)
No siempre los que decimos que ayudamos, aunque aparente hacerlo??????
Lo que obtengas, es por merito tuyo solamente y no le debes nada a nadie, aunque lo aparente.
Aunque Figuera no lo especifica en dibujo de patente, si lo dice en escrito.
Although not specified in Figuera patent drawing, if it says so in writing.
It mimic a conventional generator, one North follows South.
In a generator that I have (18 holes) triphase, 18/3 = 6 coils per phase, each about 240 laps + o -, 6 * 240 = 1440 approximately. (The rewinders as calculated by type,  size and of iron). 4 electromagnets = 2 poles, about 200 rounds each. (I have not counted the turns, he told me a colleague)
As you say you have some stuff, lf a generator (old or broken) cables leading to the segments (collectors) and feed the electromagnets with the gadget Clemente, you will give an idea of what other ...  can be measured with the voltmeter to bond terminals ... ( exciter winding, if available)
What you get, is yours alone merit and does not owe anyone anything, it is apparent.
Interezante exhibition of Bajac:
Reactancia o balastro: Desde el punto de vista de la operación de la lámpara fluorescente, la función del balasto es generar el arco eléctrico que requiere el tubo durante el proceso de encendido y mantenerlo posteriormente, limitando también la intensidad de corriente que fluye por el circuito del tubo. Solo fue una idea que se me ocurrió, al ver la página de hyiq.org.
Ballast: From the viewpoint of the operation of the fluorescent lamp, the function of the ballast is to generate in the  tube the electric arc required for the ignition process and keep subsequently, also limiting the current that flows through the circuit tube. It was just an idea that occurred to me, seeing hyiq.org page.
Doug1
"It mimic a conventional generator, one North follows South."
  No.
  North and south pole are one magnet in normal gen. Path of magnetic lines is from end to end of magnet. Pick up coil is placed so as to be between the magnetic path as the magnet passes around or by the pick up coil. In some way the magnetic path is a complete circle.
  Stated in the patent not a transformer nor a moving generator, only the field moves.
  Normal example of induction is a rotating magnet the field swaps end for end as it rotates past the output coil. The coil sees nsnsnsns.... Without using a transformer nor a rotating magnet how do you imagine you can make the output coil >>>see<<< or be influenced by the same field motion as nsnsnsnsns......Keep in mind nothing is moving not anything physical. If you think your going to set it up n/s and just power it up and down with your pick up coil in the middle it wont put out much. Just like it would act with a permanent magnet and coil. You would have to push the magnet all the way through and back all the way through the other way which is the same as rotating end for end. That wont work unless you can cause the pick up coil to see a reversal where one does not exist.
