Doug1
 I wish all success using IC's but I personally dont see how it would function the same way as analog systems would. The manipulation required to create the magnetic field of equal strength from two different value inputs into the inducer coil is not explained nor obvious using ic's. The incremental increase and decline is there but it is a singular coil input. Imo it will not be able to run without the source to operate the ic's because the portion of the output to be used over again will be lower or lesser then the source regardless of how it is converted. An increase in voltage potential will come the expense of amperage and visa versa.
  Im not saying anything is impossible, just that I don't see it using ic's.
marathonman
JUST REMEMBER THE OUTPUT COILS CAN BE SERIES AND OR PARALLEL TO ATTAIN YOUR DESIRED VOLTAGE  (ISN'T THAT WHAT fIGUERAS SAID)
the first pic is food for thought from above.
the second pic is my two channel board  (very rugged little sucker)
hanon
~Maverick.~
Quote from: hanon on January 01, 2015, 11:05:52 AM
A very enlightening video:
Bucking coils:
http://youtu.be/Z-V1z2TdQJA
Happy new year!!
The hard part with excepting this setup is that people have been chasing FE for decades. Some of these people are extremely talented and educated in the art of electronics. What would be the odds that over the last 30+ years the hundred of thousands of people who experiment haven't tried this winding setup?
Are we really looking to maximize output of a coil? Wouldn't a coil itself be limited if it were the source of additional energy? If we say that coils only serve the purpose to extract energy then something else must harness the energy. I dont know the answer, but what I do know is that history has shown that people have tinkered with different coil combinations for the last 30+ years. All the results are basically the same......... nothing.
My avenue of approach is a bit different then others, I am suspecting that vibrations in the actual iron core play a large role. As a general example we know that if we add iron to an air core coil we magnify/strengthen the magnetic field. So what if the iron was conditioned more. If the magnetic field originates from the iron what if there was a way to precondition and/or explode the magnetic field outward and inward.
Like everyone else I'm still on "square one". I have taken the advice of people here and built a very flexible setup for experimenting. Having said all that ...... keep up the good work, I'm sure we will succeed.
marathonman
Hello everyone,
I like the set up of "Bucking Coils" and the intensity is raised and lowered by the resistor Transistor combination but my only problem i have is how to reverse the polarity of the coils. just raising and lowering the current will not give me AC in my output coils, the north stays north and the south stays south. if i can come up with a circuit that reverses the polarity i or we rather will have it made.
can someone please help!
