gregg2597
Iam going to have to get that translated!
Iam va a tener que conseguir que traducido!
ignacio
gregg2597 y demás foreros, donde mejor explicado esta, es en las patentes.
El ahorro que se produce (¡histéresis!), es que no haya cambio de polaridad, ¡por eso la configuración en las patentes! El que un hierro (núcleo) tenga que cambiar su polaridad en el tiempo, cuesta mucho trabajo (tanto que no le da tiempo a las moléculas de asimilarlo) Por lo tanto, se induce con los electroimanes una alternancia con solo una polaridad y sin que tenga que cambiar la polaridad de la bobina (¿electroimán?) inducida.
Hay que dar sin esperar nada a cambio, y sigo sin tener idea.
traductor google:
gregg2597 and other foreros where this is better explained in patents.
The savings occurs (hysteresis!) Is that no change of polarity, so the configuration patents! Whether an iron (core) have to change its polarity in time hard time (while there is no time to be assimilated molecules) So is induced by the electromagnets alternating with only one polarity and without having to changing the polarity of the coil (electromagnet?) induced.
You have to give without expecting anything in return, and still have no idea.
gregg2597
Thank you for your reply.
I think I understand now.
Gregg
Gracias por su respuesta.
Creo que entiendo ahora.
Gregg
gregg2597
Thank you shadow119g
Since  the leds are fluctuating with the different resister values at each output , that tells me the Ardurino program is working.
Now I can setup the transformers. Small of course, but with this setup it should have a noticeable output load.
Gregg
