NRamaswami
Here is a clarification on the COP>8 output obtained. There were lot of questions earlier how did we measure the Amps to be 20 and Amps cannot be 20 when we have not connected to any load and only voltage without load can be seen. Easy friends. 620 volts and 50 Hertz current is deadly. Can we take a risk. We cannot. We must give it to a step down transformer and step it down and then give it to the load. But we did not give to the loads for we did not have a step down transformer. So how can we measure or see Amps in the Ammeter. This was the question and I elected not answer that in my earliest posts.
It was a common sense decision. We cannot take a risk with high voltage.
We connected the two ends of the secondaries two earth points about 7 feet apart. Nothing more. Ammeter immediately showed 20 Amps and the volt meter showed 620 Volts. Load was provided by the earth between the two points. I do have a doubt that if we provide the frequency at about 7.8 to 20  Hertz we will be creating a resonant frequency to the frequency of earth. At that point the wires must be able to tap the telluric currents. If the distance between the two points is higher the resistance of load is higher and more amperage would be shown.
I have seen other earth based generators that are cop>1 but it seems to me that by connecting a high voltage transformer having thick wires and giving to the two wet earth points we should be able to take power from the earth points. High amperage is possible if we use thick low resistance copper poles inserted in to earth and connect it to step down transformers to get 220 volts.
Figuera shows clearly that the primary negative wires goes to Al Origin. It is deemed to be battery. It can also be two earth points connected to battery negative. Once current is taken from the positive the output from the secondary can be given to the positive and a very low amount of input is enough to rotatethe rotary device. It uses a small DC motor and uses a small batttery.
This is how we achieved COP>8.. Figueras Al Origin means the source. The primary wires take negative charges and the source of Biggest negative charged body we know of is,  Planet Earth. So he has connected the primaries to Two earth points. This is my feeling but we used only AC current from mains. The device is of the type where increasing the voltage increases the amperage without being connected to earth. It is possible that by increasing the turns and giving to a step down transformer we may be able to reach 20 amps naturally and earth points may not be needed and if that is the case a self sustaining generator using a battery, inverter, modified Figuera device, step down transformer and connection back to the inverter to recharge the batteries and excess output may well be possible. But we have not tested it. We have achieved cop>8 results only by connecting to Earth.
Barbosa Patents also show very thick wires being connected to earth.  The Peter Grandics Patent also connect the high frequency high voltage secondaries to two earth points to claim a cop>100 output. It is possible that ths method takes the amperage from the telluric currents.
I'm convinced that the primary being connected to Al origin is nothing but two wet points. The two primary wires are shown in the drawing well separated indicating two earth points at a distance. The device has been shown to work as claimed and inspection certificate was also provided. This is a device any one can make cheaply.
In my case the initial voltage was quite high. 220 volts. Hanon has repeatedly indicated to me that the input was 100 volts and 1 amp only and output was 20000 watts as stated in BuForn Patents. Without the earth connection I'm not able to believe that it is doable. 'With the earth connection yes more than that is doable. it is a known science. Known fact. Too many patents are out there and no patent can be obtained nor granted for such devices.  I have seen comments did Figuera did it or not? Really very insulating to the Genius of the Man. Hanon must be complimented for bringing out full details of a real working device that can be replicated by a dummy like me. I had to spend a lot of money.  A small device can show cop>1 performance easily. I'm not inclined to build it for whenever we have tried after learning this some staff get injured.
I have provided full information. Tariel Kapanadze devices also use two earth points but that is very high frequency I guess. He is dipping in to Telluric currents. And wet points are essential for that. There is nothing else.
NRamaswami
Hi All
This thread seems to be dead and no replies. Any way I will post this info here. Patrick Kelly felt that the information is given in several posts of mine and it is difficult for any one to comprehend that. So he has asked me to create a comprehensive file.
The attached file shows how the device was wound and constructed in experiments conducted in July 2013. The output was cop>8. I do not have pictures and videos and so we will rebuild that device and post pictures and videos.
This file will also be given to many others. In view of the fact that I only replicated what Prof Figuera and Buforn did in the 1908-1914 and I only replaced the interrupted DC given from the battery by them to AC, I'm not filing any patents for this. This info is open source.
I have made other devices that can be made based on the same principle. I have also found that it is possible to create a manifold increase in the cop>8 device if the input is given through a spark plug. That becomes high voltage high frequency current. Output current is also hi frequency and it needs to be brought down to low frequency. Tariel kapanadze device is based on the high frequency input. High frequency current is not dangerous. It will not penetrate the body due to skin effect. Hi frequency pulsed dc current can in fact kill all parasites, virus and bacteria in the body and that is what is used by the Violet Ray deviec and the zapper device of Dr. Hulda Clark.
Patrick Kelly helped me prepare this document. He did not provide any direct guidance and he did not take part in the experiments. We learnt this all by winding ourselves. One of the persons in my team who worked on this project died out of illness. He was advised that his life span is short and he had gone through three intestinal surgeries before joing this work. He was not married and passed away due to stomach complications after being treated in a hospital about a few months after we did this experiment. I had gone in to poor finances as we did this experiment and we felt that this is a cursed field and avoided doing this experiments after that. Patrick and Hanon provided some financial assistance after this to motivate me to redo the experiments and when we restarted an experienced carpenter got hurt in the eyes on another project. I was so frightened that I stopped. We did not receive any threats from any one.
Though I'm a Patent Attorney I do not feel it is ethical to modify the device and file any patents for this device. I have only replicated what Prof Figuera and especially BuForn another Patent Attorney did in 1908-1914. Figuera did not disclose the best mode of operation of the device. BuForn did in his last patent and discussed extensively that the device functions due to its ability to attract and focus the Geomagnetic waves flowing from North Pole to South Pole.
I will post photos and videos on how to replicate if time and money permits.
I must give credit to Patrick J Kelly for compling his book. Without that I would not have studied this. I must give Hanon the main credit. He wanted to revive a hero in Prof. Clemente Figuera. Without the efforts of Hanon it would not have been possible for Patrick to put the information on his book. Without the two I would not have felt it to attempt to redo this experiment.
I'm not asking any one to replicate my experiments as the output is very high and comes at dangerously high voltage at low frequency current. if you are attempting any replication I'm not responsible for accidental injury or injury that you may suffer due to poor insulation or carelessness. The attached material is for educational and clarification purposes only. Do not touch the iron rods in empty hands. The iron rods in the magnetic core also carry high current. We have done our experiments after insulating the rom very thick papers and card boards on all the walls except the ceiling and insulating the ground with a  thick plastic sheet first and then put two 3/4 inch thick ply woods one on top of the other on the earth when we did the experiments. No water was allowed inside. Apart from taking these precautions we used rubber chappels and rubber gloves and kept one person to switch off at any instant as a safety measure. If you use the information in the attached document and do any experiment you are responsible for the consequences. If you are located in different places this device may produce higher or lower outputs based on the windings and number of turns and length of the wire and the magnetic field of the earth present there. I'm not assuring you that success would automatically come and if you are doing any experiment you are doing so at your own risk.
RandyFL
Hello All,
We're not dead...
I have been studying air gap cores...and have also been keeping my chair warm...
All the Best
Randy
a.king21
Nramaswami: I see no reason why your device cannot operate at much lower power levels.
Congratulations on going big. That took a lot of guts.
In fact your project scares the hell out of me!
NRamaswami
A.King21.
Thanks for your kind words. It is possible to bring down the input by using very large core for primary and using a very large large number of parallel coils and large iron. It can be brought down to significant levels that the input would be only about 110 watts. If you use lower voltage then very very thick wires will need to be used. Lot of wires and lot of turns and then it would also require more iron. Thicker wires have lower resistance. So can carry more amperage. But again in order to get the turns needed you need to have a lot of wires. It will cost a lot of money.
We have stopped doing this. As I found every one doing this stuff suffers from poor health and their finances suffer. I was no exception.
Transformers are built for low cost and are a trade off. For lower cost they create as much of power as possible. They are very very leaky by their design. The square plates leak magnetism to the maximum possible extent. The induced current is minimum. But all this ensures a very long trouble free life for a transformer. So the design was one for the lowest cost, long life and stable operation and effiency was traded off. They were not intended to be generators of electricity. if we modify them they can be used as generators.
If the device were to be built for lower voltage in mind, then the amperage should be higher and the device needs to be bigger. Possibly it can work at lower voltage and higher amperage using a shunted coil design as it is obvious to me. But we have put this info as open source so others can do it. We are not keen to redo all this. We have had enough..No more of it.
When we use a solenoid structure reverse is true. Magnetic losses are minimized and they are lost only at the poles of solenoid. Not all around.
