0 Members and 23 Guests are viewing this topic.
gyulasun
Hi NRamaswami,
I am afraid I did not do my 'homework'  in this topic correctly, sorry for this, in fact I follow this thread only occasionally.
So I went back and did some further reading and I find your posts  #2129,  2133,  2134 (and some more recently) where you described how you built your setup and attached some pictures. I will return to this in a few days with some questions.
Now I would like to ask what switch did you use to have the pulsed DC and approximately at what frequency did you operate the switch. If you are not at liberty to tell this, that is fine with me. To clarify what you did, let me say what I think you did:
you made a coil with 1000+ turns (I assume you used the 6mm OD iron rods for the cores) and you simply connected 5 lamps of 200W each in parallel with this coil. And you connected this coil to the 250V DC voltage source (you described the source) via a switch and you got 270V across the coil i.e. across the paralleld 5 bulbs. Is this correct?
Thanks, Gyula
NRamaswami
Hi Gyula
I do not know at which frequency pulsed dc was given at 250 volts.
I do not know much about terms so please forgive me if I make mistakes.
In India we get 220 volts and 50 Hz current from mains. Voltage fluctuates.
We connected the variac to mains. Output from variac was connected to a diode bridge rectifier which converts AC to sign wave pulsed DC if I understand correctly. Upto 220 volts from variac there is no change. But when we go above 240 volts the output voltage goes higher than input voltage and varia is limited to 250 volts and when we reach maximum the output voltage on load increased to 270 volts but when weremoved the diode bridge rectifier and gave AC this was not repeated and voltage decreased in the load.  The coil was wound with gaps ad in the gaps we put a lot of iron powder and paste
NRamaswami
We were trying to make a Cater Hubbard device and that is the device that produced the re did not build it properly is my feeling and the construction was wrong. I can post pictures if you want.
RandyFL
Hello All,
Rams,
I'm sorry... I didn't realize you were doing this in DC...I assumed you were just connecting to the AC mains...In the States we receive two wires of 120 and a neutral and each house is grounded in a single phase system... our main electrical appliances Air Conditioners, clothes dryers, stove tops and hot water heaters use 240 and everything else is 120 at 60 hertz ( sine waves )... I would imagine everybody else in the world is using 240 at 50 hertz ( cycles ) hence your DC cycles are 50 cycles ( hertz ) the unique thing about the circuit that Patrick used is that you can use any amount of DC current you want... for ex. I am using one 12 volt lawnmower battery... you could have endless current by adding in series batteries...
Gyula,
not to beat a dead horse... so what you're stating is everything is based on the input ( lenz law, flux, induction, gap potential and secondary  )...
X amount of energy from the source is going to produce Y amount of energy... no more... no Less...
is that correct...?
All the Best
Randy
NRamaswami
Randy;
The modified Figuera device we did and I have explained was given AC input from the mains.
The pulsed DC input was given for the Cater Hubbard device we built earlier and which did not work. You have seen those photos already. We have not tested the figuera device with the pulsed DC. We will test in future and post the results.
Joesph Cater explains in his books that Coils have no impedance to Pulsed DC. I do not know if it is correct but it is a fact that 50 volts stepped down input it requires 4 times the number of turns and length of wire to hold an electromagnet stable. If for example you would need 160 turns of wire to hold a stable electromagnet at 50 volts AC, for pulsed DC you would need 640 turns of the same gauge wire wound on similar dia coils.
