RandyFL
Spot on...!
That's an excellent idea... Thanx Doug1. The obvious isn't always see able when you're focus on something else.
It wasn't the circuit... it was the cheap parts.
Here's the circuit1 running.
IMG_1918Circuit.MOV
IMG_1919Circuit2.MOV
And the second circuit...
My point in this is to show you can run the circuit with 9 volt batteries... the circuit1 the battery is almost dead... and Circuit2 you can barely see the leds light in front of the BDX53 s...
I have an order that was shipped out Friday from digiKey that has 9 position dual row barrier blocks and jumpers plus ten 12 volt red leds  for the transformers... I also have six 10 watt .2 ohm resistors and one .1 ohm resistors for the barrier blocks... the transformers have been wound already...
If after all that...If I don't get the results I get more iron ( bigger )...I will test everything I can with the circuit Patrick designed...If it still doesn't work after all that...I will be happy to try the " other " apparatus...
All the Best
Doug1
It only counts if you can get it to run off itself and power a load.ie disconnect the input power.
"As seen in the drawing the current, once that has made its function, returns
to the generator where taken; naturally in every revolution of the brush will be
a change of sign in the induced current; but a switch will do it continuous if
wanted. From this current is derived a small part to excite the machine
converting it in self-exciting and to operate the small motor which moves the
brush and the switch; the external current supply, this is the feeding current,
is removed and the machine continue working without any help indefinitely."
RandyFL
what I would like to see at this point is 9 amps from a 12 volt lawnmower battery going to the 1st position of the 7 resistors....
Doug1
Randy
  You could save yourself a lot of extra work following simple rules that never wear out. The shortest distance between two points is straight line and so on. Square wheels suck but if you feel you have to experience it for yourself you might find the number of people who willing to ride with you are limited. On the other hand the number of people willing to watch will be limitless.
  A good self test is can you apply and identify how the process would work in any device that works off of induction by being able to explain it to yourself and verifying it with known proven rules. When you run out of arguments with yourself and the rules then maybe it is time to apply an understanding to a real and physical experiment to verify that established understanding. If all goes well, then it is time to work out the bugs in designing a useful practical device that does something useful. Never trust the cool aid.
Doug1
 One of the statements in the patent which seems simple and more then likely not even given any attention :Watching closely what happens in a Dynamo in motion,". Close examination,formulate methods to see what normally is not visible.Know what your trying to do before you start.
