RandyFL
Hello All,
Update...
Have tested this circuit ( in the video ) its the last remaining breadboard circuit ( I have to order more parts ). In the video the 8 flashing led s represent the " base " for the 8 BDX53c s power transistors... I disconnected the 2nd breadboard with the BDX53s along with the resistors and will start placing them on the barrier strips ( blocks )... I will have a run battery for the circuit and a charge battery for the power transistors... I kept blowing out parts ( in the videos my parts are sticking up and could short if ( when ) leaned on ). In the future I guess I'll have to solder them... but for now bread boarding is very easy...
On another note... " fuses ". I will start using 1 amp fuses in the breadboards ( circuits )...I have been told that the fuses protect against fires not components...and I'm still not convinced that components can't be protected with fuses...
All the best
IMG_1971June11.MOV
ATOM1
Why bother re inventing the wheel ??? I do believe that was already mentioned ! Is it worth the bother I don't think so ! So a frequency pulse wave and a tiny motor hahahahahah OK HAHAHAHAH r u planning on planning on powering a super slow car toy hahahahahahah
It would be far more productive if you were to study more the principle of such a thing and see if it has any maths that will make sense of it.. The term P wave compression will help first discovered in 1786 or round about that time but they were using water sending a wave from two ends that would meet in the middle forming a P wave dynamic . As the waves pass they continue without loss of speed the drop off is when the wave collapses. I made one with a cylinder under the P wave with a spring on a piston. The piston head was connected by long arm to each end of the water canal stimulating many waves after say 1 minute there were P waves along the canal of water... The P wave under the piston never stopped functioning. That was good enough for me but I could off added more pistons ect.
Gravity was the main energy input but in the micro generator it is bosons filling up under the wave functions and bosons are tiny but there are many of them to many to count.... The point is find the source of the energy its mass and what stimulates it to function than stop and truly think it through. The micro generator will not loop over infinity its to dam small with a rather high resistance. Not enough particles in the stream to be of any real use.. But there is a tiny amount of free energy but it comes from somewhere so is it truly an O U technology..
It is not as good as a capacitor super flux electron field compressor that is self charging and lasts forever or a simple alpha particle feed transformer or even a unified field oscillator or a static pump....
You guys are so stuck with playing with words and never no formula ?????? You read to many terms in electronics and dream of a self powering lap top sorry its all been done .! But not like that !
IT IS FAR MORE IMPORTANT TO FORMAT THE FORMULA THAN THE BUILD OF THE HARD WEAR . The language you are using is wrong its all mumbojumbo its not in a energy language and that is because you don't understand particle physics and are stuck with circuits and little bits and bobs ...... Don't be offended please tel me or yourself how many electrons in 1 amp and what is a volt ? Why does ohms law not permit a free energy equation over resistance ? What does the threshold peak wave harmonic mean and why can you not do this trick with a square wave ????
What is the correct priming point in the wave to stimulate the advanced frequency you hope to gain ??? Evan the so called inventor cant answer these questions and is why he never got passed the first prototype. I am not trying to be cleaver but in truth sometimes I am a bit scatty all over the place but like all theories in chaos there is always a point of rest and this is one of the points in time and space I set most proudly on... I has now got my detailed focus !
Keep twitting around with tinkering hahah that will cost you a lot of time ! Time is worth more than money ! knowledge is worth more than time. Draw up each wave paten please don't bother with all those O S pictures they don't show you the mass just the crest of the wave....
The kinetics of energy in the stream are not at the speed of light but voltage is with the particle mass lagging behind as not all the mass of the wave is equal even if your O S looks like it is ..... There are holes in everything including an electron wave and no electron is equal in distance to each other the O S DOES NOT SEE THAT BECAUSE IT IS ONLY FILLING THE WAVE ! NOT SEEING IT !
So this is a secret and knowing where the heave waves are is where you place your input pulse hahahahahah ! Also electrons have strangeness they do strange things they are not rolling they are quantum jumping in and out of space time, The real value of electrons is always half when in the currant and twice that at the load...
Its a bit tricky trying to find where an electron will pop up hahaha But one can always know where the heavy wave is along its harmonic try study the 5ths of scale as all strings have them. Do it on a piano hold down the 5th note of the scale than play the 1st note of the scale and both string will resonate.... Its the same thing but with a piano hahah
All events are all natural laws what you find in electronics you will also find in the natural world and this is the best way to study quantum events at the micro level or even the plank level , if it does not exist in the natural world than it does not exist in electronics physics or chemistry ect ect .....
This will help you leaps and more leaps hahahah If your really lucky you will measure you will measure the length of the wave function and not just count the peaks than you just look at it like a guitar string where the frets get larger at one end and smaller at the other it is with the bass that the string has more energy and sounds the loudest. ALSO ELECTRONS HAVE X Y particles that construct there mass hit at the right point and they will separate for a fraction of time creating a void that time and space will fill up with neutrinos bosons some gravitons and as the door closes some electrons try and jump into the void.....
Count them !
GOOD LUCK
ATOM1
RandyFL
Hello All,
The last base is taken out of sequence and fed into another breadboard which feeds a PN2222a ( general purpose transistor ) with a second 9 volt battery as shown in the video... I think the BDX53 max s out at 9 amps and the 2N3055 s max out at 15 amps ( I have to check again )...
All the best
PS the Video... is over the picture.
IMG_1988June14.MOV
JohnMiller
Hi Randy,
are you still struggling with your circuit? There are some more prameters to obey at use of transistors. PLease understand you cannot change parameters and expect Patricks circuit to behave same.
Just now I am not aware of what voltage und what base resistors you run your driving circuit. What voltage is at your load circuit, What load (LEDs, coils ??)
I am willing to calculate if I get those data (alternatively a current circuit diagram).
John
