Doug1
" so what you're stating is: the larger magnet wire on the secondary has no bearing on output"
  That is wrongly stated but not wrongly intended.  The size of the conductor of the secondary is independent to the effect of flux cutting compared to the size of the primary. It is the quantity of flux which is being cut by the size and length of conductor which is separate from what caused the flux. They are two separate things treated separately. In essence they are even controlled separately.
Doug1
 Why do you think lenz law is such a bad thing? If you use it to your advantage it would be good. Maybe it would serve you to read it again and don't skip over the links thinking you know what the hyperlinks mean. https://en.wikipedia.org/wiki/Lenz%27s_law
RandyFL
my intent...
was to find if Bajac, woopy and Kehyo did that... I ass u med they did but I don't want to take it for granted... Woopy and Kehyo never showed " that " in their videos.
Clemente drew the shapes in the Dibujo de la patente de 1908 / Drawing 1908 patent.
( the first picture )... in drafting school we drew from all sides ( Clemente didn't do that in that picture ).
My goal is to find out if pulses of energy multiply in coils or by bifilar coils... ( as I am sure everybody and his brother is too )
Quote from: Doug1 on July 04, 2015, 10:41:01 AM
noted...
Cheers
ALVARO_CS
@ NRamaswani
Hello
Does this schematic depicts correctly your description ?
Thanks
Alvaro
hanon
Quote from: Fernandez on June 27, 2015, 11:29:57 PM
You can create a simple motor effect with a magnet, piece of iron and a battery. Take a strong magnet and place the iron on one of the poles.
For this you can use a 16 penny nail. Connect the iron(nail) to the (-) side of a AA battery. Take a small wire from the (+) side of the battery and touch the bottom end of the magnet.
You will see that the magnet rotates.
In this case two magnetic fields are created in one object. That object is the magnet. The current from the battery slightly distorts the magnetic field from the battery.
Prevent the magnet from rotating and quickly introduce and remove the current from the battery the magnetic field distorts and springs back.
In this experiment you end up moving a magnetic field with a current.
This effect can be amplified with electromagnets. Build a coil with iron, tire irons work well. Spin a coil on it, start light say 12 vdc. Connect wires to the iron core and pulse the iron core with 12 vdc.
Secure the iron core from wanting to rotate, when this is done again you are creating a Locked Rotor effect as seen in a stalled electric motor.
Find a way to get the distorted magnetic field to do work, shouldn't be that hard. Give credit where credit is do.
- Fernandez
Fernandez,
From the moment I saw your post I knew that I had seen something similiar any place. I have been searching for old links and sites. Please see the link I post. It seems that Hans Coler used something similar to your proposal in his free energy device.
http://pvb.pavlabor.net/SE/FreeEnergy_27.01.08/%D0%A1%D1%85%D0%B5%D0%BC%D0%BE%D1%82%D0%B5%D1%85%D0%BD%D0%B8%D1%87%D0%B5%D1%81%D0%BA%D0%B8%D0%B5/Energy%20%D0%BD%D0%B5%D0%BC%D0%B5%D1%86%D0%BA%D0%B8%D0%B9%20%D0%BE%D0%B1%D0%B7%D0%BE%D1%80/magnetbeschleuniger.htm
I post also here the pictures from the link. Apart from the Coler sketch I have noted a very similar sketch in the Dingel HHO car or Sweet generator to the scheme I think that Figuera used.
