core
This is how the above unit operates. In the PDF I give credit to the patents used. One of them is a device from Thomas Edison. In short these are concepts taken from other peoples hard work.
- CORE MATERIAL & SHAPE:
Iron is the only material used here. The shape of the core is extremely insignificant and does have to mach what is shown in the drawing. A Magnetic circuit will close regardless of the shape of the core material. To emphasize this you could create a core in the shape of Mickey Mouse with the smallest of air gaps and the magnetic circuit, providing the air gap closes via Magnetostriction, will still conduct magnetic current. For drawing purposes the core is shown square, functionality is the same regardless of shape when we are talking about Magnetic Currents. This drawing shows laminated iron sheets, in a square fashion, being used.
- SEQUENCE OF OPERATION
-Bias Circuit:
This circuit provides for a constant magnetization of the core material. The objective here is to constantly provide a low power driving force that keep the core material magnetized in a specific direction. Possible substitution here could be a permanent magnet core.
However the magnetizing force provided by this coil should be below the force required for the Magnetostriction effect. Initial voltage should be 24 volts D.C. @ .25 amps.
-PRIMARY COILS:
These coil provide the energy required to create the Magnetostriction effect in the larger iron core. It is estimated that this driving force should be no less then 120 volts @ 1 amp or 220 volts @ .5 amps. The coils should be oriented in a fashion that supplements the pole orientation shown on the drawing. These coils can be operated in the fashion shown by the Discharger circuit. If pulsed simultaneously a D.C. Output is created. If pulsed alternately an A.C. Output is created.
Resonance is of importance here. However this resonance is not electrical resonance but the resonance of the core material. The mass of the core material will dictate the required pulse frequency.
- SECONDARY COIL:
This phrase is used loosely here and used for identification then actual practice. This coil should be robust as it will absorb/transport a large amount of current. Its sequence is as follows:
1. At the moment the iron core of the secondary comes in contact with the primary core material (via the Magnetostriction effect) a large current will flow throw this core.
2. This coil, at that moment, is shorted out via a mosfet. When shorted a large current will flow through the coil increasing the expansion of its core material thus increasing magnetic contact with the primary core.
3. At the moment the Primary coil(s) are de-energized the iron primary core retracts effectively opening the core to the designed air gap. The magnetic current, that was circulating rapidly through the magnetic core is abruptly halted due to the resistance encountered in the air gap of the core.
4. At this moment the magnetic energy is thrown from the iron. It is at this moment that the Secondary coil short is removed and the coil is allowed to feed a load or a storage capacitor. The moment the primary coil is closed again producing the Magnetostriction effect the secondary coil is shorted again.
5. This procedure is repeated in a smooth fashion at the resonant frequency of the primary core material.
Taken from the PDF.
-Core
core
I want to emphasize a point here that coil and core geometry mean very little. Unlike a traditional transformer that requires calculating the primary and secondary coil for the correct output that is not required here. The primary, and its called that for lack of a better name, has one purpose only and that is to magnetize the iron core to allow the Magnetostriction effect to take place.
There is no direct interaction, as in a transformer, between primary and secondary coils. The secondary coil, and its called that for lack of a better term, simply absorbs the energy that is released from the iron when the air gap is re-established and the magnetic current comes to a crashing halt. For a greater understanding please research the patents I cited in the PDF.
Bottom line: We are using iron to focus and collect the energy stream. This energy stream is the magnetic current in a magnetized material (iron). We use a natural effect to halt the movement of this energy. Then we use a closed earth grounded coil to collect what would normally dissipate into the atmosphere. This isn't new or original, it was experimented even by Thomas Edison (see his patent) and others. Ed Leedskainin wrote about it in his book.
-Core
RandyFL
Core,
Great job on your interpretation and your drawings. Now... have you got the replication in video of where it powers up and disconnects from the power and runs by itself and powers something else...
Also...is the transformer ( for lack of a better word ) stand alone or is it 5, 7 or 8 array...
All the Best
iflewmyown
Core,
I think you have nailed it. Some time ago I spent a large amount of money and 6 weeks full time work trying to replicate this generator. I learned that there was no combination of coils and cores that would work without an unknown ( to me ) factor. Thank you!
ALVARO_CS,
Thank you for the translation work. I did a google translation of part of this patent almost a year ago, but I knew it was lacking and your's cleared up several points for me.
Garry
hanon
Alvaro,
Yo have done a great work translating the patent from 1914 by Buforn !!! I am sure that your work will be of great value to those wanting to replicate the original Figuera´s generator. This patent put into light some more details than the patent from 1908 because it defines the induced core orientation and it gives to arrangements for the induced coil with respect to the electromagnets. In this patent it is clear that the three cores must be aligned in a straight way :
but not forming a kind of transformer with the induced coil touching the 4 poles as Bajac stated in his personal proposal. That proposal from Bajac is wise, genuine and very interesting but it is not what Figuera porposed first in his 1902 patent, later in his 1908 and finally by Buforn after Figuera´s death (Buforn was a Figuera´s partner)
Core,
It is good to see new ideas in the forum. I didn´t know the effect of magnetostriction (the deformation of the magnetic material as consequence of the magnetic polarity created). I have read some info in the wikipedia and this effect it is very little: around one micrometer (10^-6 m) of elongation per meter of length in the original material. It is too little to affect the space between inducers and induced coil. But it is just my guess after a quick review of the theory, but not sure if it could be the key. I have read that this effect is the acuse of the humming sound in transformer. In the other hand, Figuera never told about switch off and on both the inducer and the induced alternatively and shunting the induced coil while the inducer was powered. These are new ideas in your design but not in the patents. In case we were looking for and strange effect in the space between two magnet I tend to think that maybe it is more related to the works of Nikolaev with the discovery of the longitudinal magnetic field. I posted this in the next link. P please read it carefully and give your opinion:
http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg449854/#msg449854
