0 Members and 47 Guests are viewing this topic.
SolarLab
Hi Core and All,
Andrey Melnichenko's discoveries might relate to this technique as well? [He's not the rich Russian guy!]
https://www.youtube.com/watch?v=F8c82ABs02M
Unfortunately a lot of his work is hard to find these days.
Anyway; FYI, regards...
hanon
Hi all,
Patrick Kelly has updated in his ebook the info referred to the Figuera Generator. Now the info presents with a higher degree of fidelity the original concepts included in Figuera´s patents
Apart from the 1908 patent, in the book now it is also included new info from the two patents filed in 1902: the motionless generator (patent no. 30378) and the generator with the rotary coil (patent no. 30376)
Link in HTML:  http://www.free-energy-info.co.uk/Chapt3.html
Link in PDF:  http://www.free-energy-info.co.uk/Chapter3.pdf
Below I post the sketch from the 1908 patent, and also the sketches from the 1902 patents: the motionless generator and the rotary coil generator.
MagnaProp
Quote from: hanon on September 01, 2015, 06:53:34 PM
Hi all,
Patrick Kelly has updated in his ebook...
Great! Thanks for the info.
Quote from: ignacio on August 02, 2015, 08:07:42 AM
es igual
Thanks. Much simpler than what I was trying to do.
DreamThinkBuild
Hi Hanon,
This is just a what if scenario, but what if those wire wound resistors were actually inductive? The "make before break" and the patent below would compress the flux through the windings momentarily increasing output to the drive coils.
US 4431960: Current amplifying apparatus
https://patents.google.com/patent/US4431960A/en
bajac
Hi,
Someone sent me a personal message asking for the data of the electromagnets I had built. Please, note that I had not checked this website since my last post. I will provide the data again in this post, and then may not return to this forum for months. I apologize but I do not have the time to post, so my reply should take some time.
I have built two electromagnets for the Cook's device. Each electromagnet consists of
CORE
iron steel: 1018,
relative permeability: 2,540
length: 24 inches
Diameter: 2 inches
INNER COIL
length: 22 inches
diameter: 2 inches
turns: 900 single layer of #24 AWG
measured inductance: 10 mH (without outer coil)
This inductance is very different from the calculated values, which are usually larger than 3 H.
OUTER COIL
length: 21 inches
diameter: 2.5 inches
turns: 380 single layer of #16 AWG
measured inductances: 1.09 mH (and 2 mH with inner core-coil assembly)
I will start the tests for this device. A major challenge is to determine how to excite the device. For the excitation, I will also use two electromagnets (shown in picture) located about the mid section.
I have also built a section of the Figuera's 1908 device. It was a lot of work because I have to cut Silicon steel sheets with scissors. Then, it was the hammering and drilling. See the pictures. The data for the electromagnets are:
'N' and 'S' electromagnets:
length: 10 inches
width: 1.5 inch
interface surface: 1" x 1.5"
turns: 1,050 multi-layers of #18 AWG
'Y' electromagnet:
length: 10 inches
width: 1.5 inch
turns: 709 multi-layers of #16 AWG
Whe 60 Vac was input to one of the side coils, the output in the 'Y' coils was 30 Vac. I am working on the driver to generate the two out of phase pulsating DC voltages. It should be ready for tests within a week.
The old coil winder that I bought had really paid off. It has been a time saver, once you have the set up, it is so easy to wind the coils. It was money well spent.
I should be very busy for the next six months. I will not be able to post. However, I am planning on recording the tests data and publish them later.
I should get back to you by next year with the results of the tests on these new prototypes.
Thank you,
Bajac
