0 Members and 57 Guests are viewing this topic.
norman6538
Is anyone working or a simple test of these coil ideas or does anyone have an ideas about how to make a simple test to demonstrate the principle?
I'd like to see that but don't have it fully together enough to make something to get a simple test.
Norman
Doug1
Marathonman
  If your right,you should be able to build a single section unit and run it backwards supplying ac power to the output coil and seeing what comes out of the input coils/inducers. A measurable output that will indicate what the input will need to be in order to achieve the opposite which would be running it the right way round to have the correct output from the output coil.
poorpluto
Quote from: DreamThinkBuild on October 24, 2015, 05:20:47 PM
Hi Marathonman,
In patent 30378 Figuera shows an alternate version which is a little abstracted by the mechanical elements.
A 2001 Canadian patent CA2357550 by Bud T. Johnson is the closest to this setup.
CA2357550 - Electrical generator - solid state configuration
https://www.google.com/patents/CA2357550A1
I have to agree that idea sounds simple by Figuera's description it is pretty much lock an AC generator coil at the 90 degree mark and just alternate the flux cutting through the center with electromagnets.
Hi DreamThinkBuild,
Could you please give me the complete patent of Bud T. Johnson quoted above? I have done googling with no result yet.. Thanks a lot for your help..
Best regards,
Poorpluto
DreamThinkBuild
Doug1
Ploto
When your looking at the page that pops up a lot of the text is in another color because they are hyper links. Googleing his name brings up a lot of stuff.
https://www.google.com/search?tbo=p&tbm=pts&hl=en&q=ininventor:%22Bud+T.J.+Johnson%22&gws_rd=ssl
Clicking on the hyper links in the sitations brings you to other similar patents and if the name for assignee is a hyper link it will expand into more names if there are more then one person who is a partner in the patent. If you click around you'll find Bearden and a few others on what looks like a meg in another patent which is sighted. Canada lays out their patents differently then the us. I left the hyper link for all the stuff Johnson had a hand in or was linked to in other stuff.
