0 Members and 49 Guests are viewing this topic.
Doug1
Sometimes where is says applicant if there is company name along with the inventor you can click on it and Google will come back with a list which may include the art work.
poorpluto
@DreamThinkBuild Thank you very much for your kind help & quick response, I do appreciate it
and @Doug1, I'll give it a check..
Keep Figuering!
Poorpluto
marathonman
Quote from: Doug1 on October 25, 2015, 08:29:15 AM
Marathonman
  If your right,you should be able to build a single section unit and run it backwards supplying ac power to the output coil and seeing what comes out of the input coils/inducers. A measurable output that will indicate what the input will need to be in order to achieve the opposite which would be running it the right way round to have the correct output from the output coil.
Not sure about that but i am working on one section just to prove my point. have a few transformers laying around and a few i acquired so i am building a mock up. lacking the proper wire but it is just to prove my point.
i will post my findings as soon as i can.
hanon
Quote from: DreamThinkBuild on October 24, 2015, 05:20:47 PM
Hi Marathonman,
In patent 30378 Figuera shows an alternate version which is a little abstracted by the mechanical elements.
A 2001 Canadian patent CA2357550 by Bud T. Johnson is the closest to this setup.
CA2357550 - Electrical generator - solid state configuration
https://www.google.com/patents/CA2357550A1
I have to agree that idea sounds simple by Figuera's description it is pretty much lock an AC generator coil at the 90 degree mark and just alternate the flux cutting through the center with electromagnets.
Hi,
Thanks for sharing this patent. I have found it very interesting.
The winding pattern is related to the one in this old post:
http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg420569/#msg420569
The image that you linked is not from patent 30378, but from patent 30376, but the idea is perfectly expressed. The image included in that old post is the 30378 drawing plus a drawing of the proposed winding, because, sadly, the 30378 original patent do not include the induced circuit. It mentions it but it is not drawn.
A quote from patent no. 30378 that I think that it supports the flux cutting that Figuera, IMHO, used in his devices by moving the magnetic fields:
" In Gramme ring and in current dynamos, current is produced
by induction created on the wire of the induced circuits while
its coils cut the lines of force "
" The inventors believe that is exactly the same that the induced
circuit coils cut the lines of force, than that these lines of force
cross the induced wire. "
