0 Members and 55 Guests are viewing this topic.
marathonman
Back on Track------
operation of Figueras Device in a nut shell.
Hanon:  if you haven't realized  we are talking about the same thing as in your video.
hanon
But if you want to use one induced coil at right angles respect to the inducers (which is a possibility that can work) then you have to use TWO induced coils, one at each side of the central axis, or just use one coil but uncentered.  At least see 40 sec. from this video with this other set-up: https://youtu.be/ZPbWoaPUE5s?t=11m57s
With you just one centered induced coil induction in each side (left side and right side) will cancel out....because...it has axial symmetry.
Anyway it is a possibility to test, but I prefer to follow the recommendations included in Buforn´s  last patent in 1914.
https://www.youtube.com/watch?v=aCClYZp9Yls#t=3m00s
Doug1
marathonman
DUH !....... that sure was a hard one.
Hanon; in your Video you take your clear piece of plastic and shift it side to side. what do you think is going on to get that shift from side to side ? YES! you got it,  one side is being progressively powered up while the other side is progressively powered down and vise verse.
the pic below is the exactly the same as your video. as one side peaks then is progressively powered down it reverses direction  and supports the other side being progressively powered up........SIDE to SIDE SHIFT.
it doesn't matter if its North or South it will do the same thing.
marathonman
Doug1; I finally found the circuit i have been looking for in my mag amp control circuit. i had it on my computer when i got bombed from the Internet...... lost everything.  well this is the exact circuit i will be using for controlling Figueras Device.
i just hope it reacts quick enough.
