0 Members and 47 Guests are viewing this topic.
Doug1
Here is a link to a calculator http://www.kjmagnetics.com/calculator.repel.
There is a link in the frame to a pull force calculator as well. Compare the force of two permanent magnets which are the same. Pick out an arbitrary magnet but use the same magnet in both calculators and see the difference measured in terms of force for pulling compared to pushing.
marathonman
Doug1
Convert everything to force per time to get a comfortable working scale of size for all the parts. If your inducers can only exert a couple pounds of force it will take a lot of them to add up to the amount of force being used as the end product. 72 pounds of force at 50hrtz = ?watts and so on.
marathonman
 I had to read what you said a few time to grasp what the heck you were talking about but yes that makes sense. it takes so much force per time to get a certain voltage and amperage then add each coil to get end result.
so do you have a calc tool for that since my math kind of sucks.
i have a 120 IQ but because of my up bringing i have a  post tramatic brain. ie. war zone house hold,  so it is wired slightly wrong. i understand things that most people have a hard time grasping { machanical skills are off the charts} but other things are not so good.
it's 60 hz in my part of the woods.
for all that may be interested here is a NJ supplier of PURE IRON at a reasonable price http://www.surepure.com/products.php?a=17,31&o=20
Doug1
It's 60hz here as well but it wasnt important to convey the idea just an example. I havent found a calculator for it that is straight forward just end up using lots of other converters and writing it down.
