Doug1
Marathonman
I understand you want for smaller more powerful cores but you have to consider heat dissipation. If an expensive material allows for a smaller size will it result in over heating under operating conditions like the ambient temperatures it may be subjected to?
Almost everything can be converted to something ells ,hp to ft pounds ,watts to hp, heat to watts. Watts to watt seconds was as small a time I could find, just have to break that down into 60 cycles per second yourself which seriously reduces the force as a constant to about 10 to 15 lbs per set being shifted the distance occupied by the Y coil. Even the number of magnetic lines per sq cm of material and the amount of current density can be converted although not as easy.
  It may sound a bit nutty but a paper clip on a plastic straw provides a quick probe to determine the point of intersecting fields. Has just enough flex to not be rigid and able to trace out the field as it is moved along the coils. It will even vibrate when you find the center point so you can make adjustments in the alignment with out spending a paycheck on expensive equipment.
marathonman
I am aware of the heat dissipation and know that i can use slightly smaller core as opposed to laminate but it has to handle the amount of your projected flux count and not over heat. i will have a small sensor attached to the core to monitor the heat.
I canceled my over seas order because they took to long. i will be ordering a test piece from the above NJ company. i will start with a 1 1/2" round bar of 99.8% pure iron but in the mean time i am assembling some very low tech stuff just to prove my point.
i have a oscilloscope that i will be using to line up the cores to get the phasing right as i am assuming that the phase of the secondary is used to aide the primaries as shown in the cutaway in most of the patents. i am so stupid to have not caught that earlier on in my investigation of his device.
see Figueras was hiding the fact that there was a gap between the primaries and secondary (being properly place) to get the proper phasing but Buforn  not being so cryptic shown the gap in his cutaway drawings. (purposely or not it is their)
if the primary was right against the secondary it would be hit with out of phase signal (BEMF)  but by adjusting the core back it can be timed to be in sink with the phase of the secondary (180 out) to aide the primary reducing the power draw of the primary.
I tried to find the video that HANON posted of the hall sensor dealing with the phasing but i couldn't find it.
you could be a little more helpful Doug but in the long run i will get it right.
PS. PARIS ATTACKS = GOVERNMENT FUNDED TERRORISM !
antijon
Marathonman, you're right about the patent image, but I think it doesn't affect the design very much.
According to Buforn patent 57955:
Quotewe will just have to interposed between each pair of electromagnets N and S, which we call inducers, another electromagnet, which we call induced, properly placed so that either both opposite sides of its core will be into hollows in the corresponding inducers and in contact with their respective cores, or either, being close the induced and inducer and in contact by their poles
@ Magnaprop, I haven't had good success with my recreation of the transformer, but I realized it's operation is completely different than I thought. If you watch Mr. Balush's video, you see the two secondaries' cores side by side, then the primary wrapped around it. This must be an integral part of the design.
Hypothetically, with a transformer, if the current drops on the primary this indicates an increase in reactance, due to an increase of inductance. This is only possible if the secondary produces a field in the same direction as the primary. A normal transformer is the exact opposite, the secondary opposes the field of the primary and reduces it's reactance.
I'm still figuring this out, but if you have any clues let me know. It may not be related to Figueras but still good knowledge.
Found this video which appears relevant: https://youtu.be/tXno_7xXSZs
marathonman
Quote from: antijon on November 24, 2015, 10:31:59 AM
In YOUR mind maybe NOT mine.
In my mind it changes everything, it simplifies the construction and reduces the cost by over 50 %. three Electromagnets on bobbins, one straight Iron Core and some proper tuning changes everything.
