antijon
ignacio, thanks for the advice, but please explain.
marathonman, what do you mean by magnetic amplifier?
marathonman
Quote from: iflewmyown on December 04, 2015, 05:38:21 PM
here you go
Magnetization curve for iron
I need to know what amount of flux i need for a certain amount of volt and amps.  a BH curve does me nothing besides it is not a BH of pure Iron.....this i know.
antijon; the Figueras device is as Doug1 described. it is an amplifier in regards to the incoming signal as both halves are working together. as one is gaining the other is receding, but as it is receding it aids the Gaining electromagnet in the same direction lowering the amp draw on the gaining electromagnet and helping amplify the signal without direct interaction as would be if it was a south face electromagnet. see if it was an south face electromagnet it would interact with the north electromagnet and act as one magnetic bar with a north and south poles. there fore you could say it is a push pull amplifier
one half of the Secondary coil is negative and the other half is positive. that's why it is so important to get the spacing correct. that and the fact that the BEMF confronting the primary has a role also.
if you have a coil hit with a flux of 50 volts and so so many amps that is all you get but if half the coil is hit with 50 volts positive and the other half 50 volts negative then the net volts are 100.
thus you have it's named  "Variable Inductance Cascade Amplifier".
antijon
I agree. And I think your phasing device is a good idea too. But you may not have to worry about saturation. Only experimenting will tell, but hypothetically, when one coil is increasing it will always face an opposing field until it reaches the maximum current, and the other reaches the minimum. So, the opposing field will always act as an impedance. Not to mention the load which will also act as an impedance.
I think what you mean is how much power you can get out of that core size, right? Maybe try this transformer calculator: http://www.giangrandi.ch/electronics/trafo/trafo.shtml
marathonman
YES SIR, we are now on the same page !
yes that's what i mean and thanks for the link. their is no pure Iron in the bunch but it will do.
this is a good day in Figueras land.
well maybe not according to the calc tool it says i have to have a gigantic core and that cant be right ?????? ARG!
