antijon
Well, hypothetically, you could always increase the frequency to make up for small size. If it's true that increasing the commutator speed also increases EMF, then you could just run it at high frequency, rectify the output, and power a typical inverter for 60HZ.
But bare in mind that the calculator is for transformers. It's all about efficiency and maintaining low magnetization current, and preventing saturation. Some of these things may not apply.
marathonman
This is very true antijon, the calc tool was designed for a transformer not Figueras device so indeed certain parameters will not apply.
even the calc tool it's self is off as the core of Figueras device can be taken closer to saturation than a regular transformer core and retain zero magnetism.
he was smart in choosing pure iron for his cores as it's properties are amazing. i have read else where that iron can handle a higher frequency then what we have been led to believe. i can not remember where but it said that pure iron can be brought up to the multiple kilohertz range without ill effects.
i myself will stick to the 60 hz range because i previously designed the whole system for 400 plus hz and found that the price was to high for all the parts to build it. the inverter alone is 2500 to 3000 plus step down transformer, cap bank, high power diode bridge ect..... i found a company that specializes in s high amperage transformers ie... 48 volt/300 amp and the price is not for the faint at heart.
so that lead me to stick to 60 hz and tie it to a 480 240/120 v transformer and be happy about it.  found that on ebay for 350.
that's why my design spec's was the way it is because once the distance is set between the primaries and secondary then the center supports are cut to that exact thickness and no other measurement is needed because it's all ready set for the rest of the cores. also the reason the core doesn't go to the to the end of the primary is it is Not needed. why spend extra money when one doesn't have to because you are using only one pole in this set up. now it will be different for the 1914 patent because both ends are utilized.  also in my design spec's were the fact that very high opposing forces are present in Figueras device so caution must be taken to completely secure this device. that is why i chose two center supports and large end caps secured on a very sturdy base. if a part was to come loose when someone was standing near they could quite possibly loose their life.
another thing is the magnetization will not drop that much in a straight core of iron so the BEMF from the secondary can be aligned to the primary (Phasing) as not to collide with each other. just like in Hanon's video where he brought the hall sensor back to align the signal. if the BEMF from the secondary was aligned as to hit the primary when it is coming down when the primary was coming up then the signal would more than likely aide the primary not hinder or at the least be reduced to the point the primary might not see it.
just a thought
marathonman
before everyone gets their panties in a uproar about my design spect's i think you need to reread this statement from the Figueras Patent.
it simply states that the Primary can have it's own core or it can be in contact with it's poles....meaning in contact with it's North poles.... or South if your device uses them.
I have a pic to see what i mean.....if you interpret it differently well more power to ya cause i don't want to hear flack about it.
if you build it either way it will STILL WORK JUST THE SAME,   just one way will save on core material and the other won't
marathonman
I have also been studying the wave form and pole reversals with an Geek friend of mine with Magnets and Electromagnets and we have the same thoughts about the switching and pole reversals. as each Primary is switched from High to low then at the mid way down it is switched High again never seeing Zero the polarity switches EVERY TIME. that is each half of the Secondary switches polarity 60 times a second or if your in a 50 hz Country it's 50 times a second.
take a North magnet and shove it into a coil with a amp meter attached and see what will take place. the coil/amp meter will read currant moving in one direction. then pull the same magnet out of the coil and what do you get. the currant is in the opposite direction. why did it reverse currant you ask ? BECAUSE IT REVERSED POLARITY !  you don't even have to pull the magnet out all the way when you shove it back in and it will do the same thing, currant reversal/pole reversal.
Now do the same thing to an Electromagnet and tell me what is going to happen. the currant is going to act the same as the magnet did causing pole reversal/ currant reversal all day long. certain people seemed to think that this very undeniable fact can be ignored, forgotten or just plain glossed over......WRONG ANSWER !
so another words one end will see N,S.N,S,N,S while the other end will see S,N,S,N,S,N ect.....ect.....ect....
antijon
uh, marathonman, you probably expected me to say something, but in every AC system (generator, transformer, whatever) the current* changes direction every 1/4 wave.
I don't know exactly what you're trying to say here, but no, the poles don't reverse at every peak, only at the central section. The induced field changes direction, but the induced field is never a literal field, it's only a resistance to the change of the field you are applying to the coil.
*Currant = fruit
