marathonman
Here is an assembled top view of Figueras device using round bar iron with short core and long core. bolts on end cap and set screws on center core supports.
hanon
Sam, Darediamond:
Welcome to the forum.
Sam: Take your time to read all the posts, there too much info. I remember that in october 2014 I posted a very interesting video
Darediamond: your statement about requiring a thick insulation in the inducers is surprising. I have also read that in CaterĀ“s  book (design of the Hubbard generator) and in the patent by Daniel McFarland Cook. Could you explain a little deeper your proposal or your findings?
Marathonman:  Could you elaborate the quote copied below? Is it really a working device?  When did you started to show the working device design? Your design has evolved in the two last months from transverse coils to in-line induced coils. Is there really someone that has a generator working?
Quote from: marathonman on December 08, 2015, 03:56:10 PM
i did have some guidance from someone that has had a working device for over a year now and i thank him VERY MUCH for dropping hints here and there.
Lastly I do not post many times. I saw your Mag Amplifier design and I think it wont work as you think: you can not feed power AC and modulate it at 50-60 Hz. You can not feed a 50-60 Hz power signal and modulated it with a 50-60 Hz signal. You need to use a much higher frequency AC signal in the power signal in order to be able to modulate it at 50-60 Hz with your board circuit, and later smoth that HF modulated signal with a cap. Just my thought. I already covered the subject of magnetic amplifier in january 2014. Later I just saw that the AC input must be HF. See this post: [size=78%]http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg383123/#msg383123[/size]
marathonman
"Yes"  there is and that why my design changed. and NO i will not divulge his name....only he can do that.
if you build it with the currant specs it will work.
My mag amp operates at 400hz Hanon some thing i missed to inform. ops !
and your correct about the smoothing caps...... very small one though. you said you couldn't incorporate it into Figueras Device so you gave up. well i did and i posted it.
Figueras, simplified Genius.
hanon
I guess that it is important to avoid magnetic leakage in the geometrical configuration of the coils. I tend to think that piling the 7 or 8 single groups is to get a shorter  path for the magnetic lines from one induced coil to the one close to it. For that reason I think that maybe Figuera used a series of  rectangular coils, not cylindrical, more like plates piled one after another to create a short path from one coil to the one next to it. What do you think of this?  A simple design for two group system will be with two electromagnet and two induced coils :
N   S
N   S
EMJunkie
Quote from: marathonman on November 20, 2015, 10:57:37 AM
Thank you Chris Sykes, i admire your work and appreciate your in put. I am curious as to why you wanted me to download this as i have an earlier one that i have been studying that is the information that was available to Figueras. i have downloaded it and have been reading it but i must admit it is the same info that is in the earlier version.
is their any specific section that you think i need to study.?????... if there is please let me know
i have also been studying all other patents and have come to the conclusion that all are right about the coil orientation. i have also possibly uncovered another clue to his device and it have to do with Hanon's delay effect.
in most of the patents the cores that were drawn were very long in proportion to the coils and with this set up a delay effect would take place.
also i would like to bring up that the secondary cut away in the first pic. notice that the primary is cut away also. could this be that the primary core was hollow to allow for an adjustment of some kind as in to get the exact delay effect Hanon was referring.  if you look at the other patents you will see that all of them have a long secondary core except two that have no core drawn.
first pic is my point
other pics are of long cores.
the last line on the right is suppose to be 'induced' not enduced and Sorry for the stupid large pic !
Ps. my materials i ordered have still not come in and i am really P O ed. so i haven't been able to do any test.
@Marathonman - No, no reason, just was there if you needed it.
Keep up the good work!
Take the words of Clemente FIGUERA seriously, he knew what he was looking for:
PRINCIPLE OF THE INVENTION
Watching closely what happens in a Dynamo in motion, is that the turns of the induced circuit approaches and moves away from the magnetic centers of the inductor magnet or electromagnets, and those turns, while spinning, go through sections of the magnetic field of different power, because, while this has its maximum attraction in the center of the core of each electromagnet, this action will weaken as the induced is separated from the center of the electromagnet, to increase again, when the induced is approaching the center of another electromagnet with opposite sign to the first one.
Ref: PATENT by CLEMENTE FIGUERA (year 1908) No. 44267 (Spain)
Science tells us Electrical Energy is "Generated" in an Electrical "Generator" - Energy is never ever "Generated"!!! Charge is separated and this is seen as a "Generation" of Electrical Energy.
Good Luck!
   Chris Sykes
       hyiq.org
P.S: Sorry for the late reply.
