darediamond
Figuera main achievement centred on negating Lenz effect and as such, his. Device can bé improved addind and subtracting some features.
Quote from: marathonman on December 26, 2015, 02:36:41 PM
Quote; "I base it on what have been generally discovered and achieved over Lenz effect which Fuguera also discovered that made him to successfully build the Fueguera Motionless Generator.
Completely conjecture statements based on other people not your own experiments and what Figueras actually attained in his device in which you have no idea.
Quote; "When you pulse any Electromagnet, it turns into a Socket which allows the Air base endless Wattage to Plug into it."
Our entire Universe is electric and is where the power is coming from. Figueras device is not a static electro device. it has Nothing to do with air ever. it will work in space as it pulls directly from the field within it.
Quote; "Fuguera used Pulsing DC which is Switch on and off by the ready-made dc  motor-powered mechanical switch.
Figueras device is Not switched on and off at any time. it is a make before break type setup to avoid voltage spikes which would kill the intended purpose of building up a magnetic fields and maintaining that said fields in the core with harmonious and continuous swinging of that said fields.
but the multifiller info is good as i have attained amazing results from multifiller primary coils. so much do it jumped across the room when pulsed with 100 volts DC. luckily my door helped stop the torpedo. so take Doug's warning as to completely secure your coils or those things between the legs could get amputated.
my torpedo has 3.2 inch long primaries with aprox 654 turns quad filler @ 2 T each. the funny thing is i could not get proper ohms and B field until i took my two inch secondary coil and multiplied it by the golden ratio of 1.618 thus gives ruffly 3.2 inches for my primary. then everything fell into place, so weird.
good luck.
Happy Figuering
marathonman
As was passed to me Quote;
  "once the inducer magnet is charged up with a field near it's maximum say 80 to 90 percent, the force is maintained with very little current because of lenz law. lenz law does not account for a dynamic field much less two with and inductive field in between them."
this tells me that Figueras figured out how to use Lenz law to his advantage and probably counted on it.
Quote; "The backside of the inducer core has to close the magnetic path through the air. So looking at that path in both conditions once for when it is not traveling through the Y core and once for when it is. the reluctance of the longest path through the two cores will add to the distance through the air as it returns to the opposite side of the single magnet completing the path for one of the inducer magnets. The distance adds to the reluctance decreasing the amount of difference in terms of current change. It's very small only enough to push the field the length of the Y while still having 80 to 90 percent of the maximum flux in both inducer cores."
your Quote; "Device can be improved by adding and subtracting some features."
true though the device as crude as it said it was still powered his entire house so not much more is needed.
i have been working on a sort of ACR (automatic currant regulator) on my mag amps. when a sensor on the main line detect higher currant draw like when a washer, dryer or AC unit is turned on the sensor detects this and sends more currant to the bias winding on the mag amps thus raising the timing pulse currant window to allow more currant through my electromagnets. then when the currant demand is low the bias winding returns to it's previous off state.
i have also implemented a currant regulator on my 400hz sine wave inverter  i am building that will not allow more than 1 1/2 amp on the output inverter line as to not fry my Primaries 25 awg winding's in the case of a dead short on the output line of the secondaries.
Happy new year and may the Figueras force be with you all.
marathonman
 You know i was just thinking,  that Mag Amps were developed in the United states in 1885 and being a Physics Professor at a university,  Figueras might of had access to such privileged information so he could of quite easily applied Mag Amp tech into his commutator.
this would be much more efficient in terms of power usage compared to a resistor set up that totally waste power through heat.
he could of used the commutator to mechanically regulate (make before break)  the power to his Primaries in opposite fashion.
The use of a Mag Amp for control purposes with electric circuits is primarily to regulate, within limits (maximum and minimum), variable resistance magnetically speaking.
the easiest way to draw a magnetic resistive system would have been the style he used in his patent and just to call it a resistor.
i will be working on a commutator design for who ever would want it when i get a chance.
i personally will be using my mag amp set up as i think rotating parts of any kind are as to say (1908 ish) ha, ha, ha
now that there is funny.
it's just a thought !
PS. my Christmas gift to myself was excellent results in Mag Amp and Primary testing.
Happy New Year Forum.
marathonman
 idegen:
did you know the Greek definition/name  of a donkey's swollen pus infected ass hole is ?   it's called  "idegen"
the American name is called "gofuckyourselfitis"
and the definition of "STUPIDITY" is your mother having YOU !
for the rest of the real Figuera people that have major time and effort involved, i have a "RUFF" and i say "RUFF" estimate of the rotating commutator. just so you can get a general idea what figueras was doing in the commutator area. i know a lot of people have struggled in how in the world did he build his commutator so i hope this will give some inspiration.
i hope this will help someone.
