darediamond
"If the current is given to move in series it will not produce COP>1 without the Earth batteries. If the current is given in parallel maintaining the same polarity it will increase the voltage experienced in the secondary in the middle 4 times and if the powerful magnetic field is compressed and magnetic saturation attained in the secondary core  you get the cop>1 results. If you connect to Earth batteries it is automatic."
With this statement, do you mean that the Multifilar Wires must not be connected in series?
Glenn_FR
Hi all.
A quick update, I'm not dead or ill - I'm self-employed and sometimes I don't get much time for my own tinkering...
First a couple of pics :
(Coils_in_use)
The coils I'm currently using.  The outside primaries are still my (ex. MOT) ~26AWG windings.  Still the same solid steel cores.  They can cope with about 1.5A at 12v without getting too warm.  I don't have any means to measure the field strength.  Does anyone have links/info on how to DIY a scope probe for magnetic fields - and how to calibrate?
(Bench_mess)
The breadboard is one of about 20 different designs I've been playing with to SIMPLY drive the two coils with the correct phase between them.  Two major design problems are persistent : how to minimise losses (mainly heat) using standard bipolar transistors in linear mode; how to bias the system to have almost zero idle current and minimum distortion of the sinewave (at 50 or 60Hz).  Ignore the mess aroundabout : I leave everything as-is and come back and tinker when I get time and inspiration.
One thing I did try was this simple inverter circuit ('cos I have built it on a pcb for a customer).  It outputs perfect 50% on/off out of phase signals to drive power mosfets.  For the primaries it is VERY efficient even at 50Hz : mosfets stay cool - even without heatsinks - and the coils get barely warm.  I had to add some shotky diodes to get rid of back EMF (yes, I know that I could recuperate the spikes to charge caps or batteries - but that's not the issue here).  The output signal in the secondary coil is of little use, though : just two tiny spikes each cycle - no real power.  Here's the circuit if anyone wants it :
(Inverter_circuit)
I haven't yet found the graal : simple, low power wastage, simple, only driving the coils in one direction, and simple...
Glenn_FR
(part 2) :D
Some questions :
- It's not easy to see in the photo, but my secondary coil has no core - it's air cored.  Has anyone info on this ?  Should it be cored ?
Ciao,
Glenn
marathonman
Does any one on this crazy forum actually read and study the Patents.
it seems not.
hanon
Glenn,
I also recommend to study the patents to find most of the details.
Sorry I do not understand your inverter circuit. It seems just a one step driver instead of the 7 steps used by Figuera. I do not know if it could work fine or not. Anyway I think it does not include a base DC current for the minimun current always present in both inducers.
I would recommend to use a core in the induced coil
